Network link for in wall speakers
Not Answered This post has 0 verified answers | 6 Replies | 0 Followers
expoman
Silver Member
expoman posted on Thu, Dec 2 2021 5:15 AM
Is it possible to build a module to add on to a BEOLINK Passive amplifier to make it a network link zone?  I was wondering if there is a part from a Beosound 35 that could be modified?
Carolpa
expoman:
Beosound Essence mkII
BeoLink NL/ML converter
Carolpa
Carolpa:
And Beosound Core Wink
Tassos
Athens
Hello expoman,
I am using both nl/ml converter and beosound essence mkii in a setup to drive two pairs of beovox cx100. The setup is super easy and it works like a charm! Only down side is that you need quite some space to put all this stuff and cables. Especially with the nl/ml converter which is much bigger than the essence and much much bigger than the core (as carolpa suggested) and it has no bluetooth connection to a remote (in case you don't want to control it only from your phone/tablet).
chucky
I got 3 sollutions 1 in a kidsroom with BV3000 beoamp and a core and a V1
1 in the bathroom with bV1 core and beoamp
1 in the shed BV1 and beoamp
The shed is a bit tricky. Before I used a ml/mcl and passive, works also fine but the sound is worse.
There is a delay between the core and the shed of almost 10 seconds before you here sound. It has to do with the length of cable. It is synchronised but it takes a litle time to hear sound.
Bv = Beovox
Kr Chucky
expoman
Silver Member
So a Core with power link out would activate the passive amp and give you volume control with a Bluetooth remote.  This would be the simplest solution right?
Carolpa
expoman:
Right
expoman:
or use the B&o app.
Page 1 of 1 (7 items) | RSS
