BV10-32 Source Menu Question
Answered (Verified) This post has 1 verified answer | 2 Replies | 0 Followers
Guy
Buckinghamshire
Guy posted on Tue, Nov 30 2021 4:55 PM
I have recently got hold of a BV10-32 to replace my BC6-26 as my main TV.  It's a Type 9526 with a built in DVB-HD Freeview tuner (option T2C here in UK) and the anti-reflective screen (option COG).  My only connected equipment is an Apple TV HD, connected as AV1 and selected using DTV.  (I have disabled the analogue tuner so that I can select Digital Freeview using the TV button).
Anyway, I have a question about the CONNECTIONS menu, and specifically the options that can be chosen as the SOURCE.  Why is there no V.AUX in the list, only V.AUX2?  Was V.AUX reserved for something else on the BV10s?
See source options below, taken from the manual:
Carolpa
ONLINE
Verified by Guy
DTV2=V.AUX
Carolpa
ONLINE
Verified by Guy
DTV2=V.AUX
Guy
Buckinghamshire
Guy replied on Tue, Nov 30 2021 5:22 PM
^ Thanks - I was actually reading that elsewhere just as your post popped up!
EDIT:  The information is better presented (as shown below) in the more generic Beovision 10 User Guide on the B&O support pages.  That manual also focusses on the 'non-navi' Beo4, so I am not sure if it is an older or newer manual.  Never mind, problem solved!
Page 1 of 1 (3 items) | RSS
