Beolit 12 type 2909.
Not Answered This post has 0 verified answers | 6 Replies | 1 Follower
PoulBerg
PoulBerg posted on Sat, Nov 27 2021 9:17 PM
Hello!
I would like to know, if there is a small fuse in the power supply on this model?
Mine has suddenly gone total dead 🙁
Poul
leosgonewild
Helsinki, Finland
Silver Member
I can’t remember seeing a fuse when we had mine apart for the google home mod.
Anyway, it is not easily accessible. You have to pry the thing open, and you will have issues sealing it properly shut.
matteventu
What's the Google Home mod?
leosgonewild
Helsinki, Finland
Silver Member
matteventu:
https://forum.beoworld.org/forums/t/40332.aspx
https://youtu.be/vKqTtWvFV2k
PoulBerg
I managed to dismantle the Beolit 12, and there is a 3,15 A fuse in the 230 Vac powersupply.
The Fuse was off, so thats why the Beolit 12 was totally dead.
Further mesurements neaded to find out why.
Poul
PoulBerg
No fault inside the Beolit 12.
I think the brokken fuse is caused to a bad battery-pack.
Anyway now it works again with a new fuse and battery-pack, but it is a rather complicated model to dismantle.
Poul
lawrencejmcook
PoulBerg:
Poul
Poul, where did you find a new battery pack for Beolit 12?
Lawrence
Page 1 of 1 (7 items) | RSS
