Beovision Eclipse 2nd generation software bugs
Not Answered This post has 0 verified answers | 2 Replies | 1 Follower
Sweden
Silver Member
Martin posted on Thu, Nov 25 2021 11:33 AM
I have recently got delivered a new Beovision Eclipse 2nd generation 65-inch (with G1-screen).
I have found two software bugs in the latest software version in the soundcenter:
1. The green light indicator (under the speaker) will sometimes light up even if I use VIDEO-mode (LIVE-TV or HDMI A-D). The green light indicator should only light up when playing music (Deezer/DLNA) in AUDIO-mode. The indicator works fine when playing music in AUDIO-mode but for some reason it also light up sometimes when soundcenter is in VIDEO-mode. This bug is only cosmetic but annoying.
2. The second sw-bug is regarding which sources is showing on the screen when using HDMI-sources:
If I use HDMI B (in my case OPPO-player) and put the TV in standby, and after that starting the TV again with HDMI A (in my case Apple TV 4k) it still says on the screen "Oppo-player" when it should show "Apple TV 4k". Even if the screen in this case show "Oppo-player" the Apple TV source is on and working properly. There is some bug here that makes the soundcenter not show the right source when one HDMI-source is used and after that putting the TV to stand by and after that putting on another HDMI-source. The bug is only cosmetic but annoying.
Have anybody with Harmony or Eclipse 2nd generation this software bugs also?
I hope you understood the explanation aboveBig Smile
Best Regards
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only),  Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
Dyssegaard
Copenhagen, Denmark
ONLINE
The 2nd sw-bug is also present on my Eclipse 1st gen.
I have reported it to B&O support, but the only feedback I have received so far, is a mail saying they have forwarded it to their technical team.
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
Sweden
Silver Member
Martin replied on Thu, Nov 25 2021 12:45 PM
Very good that You also have reported one of the bugs.
I have also instructed my dealer to send the same report as I have written here on the Forum to his contacts within B&O.
Let see if a correction will come.
Best Regards
Page 1 of 1 (3 items) | RSS
