Beolab 1 hidden control panel
This post has 7 Replies | 2 Followers
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,092
Steve at Sounds Heavenly Posted: Wed, Nov 24 2021 9:35 AM
Hi Beoworlders,
Did you know that B&O's Beolab 1 tower speakers have a hidden control panel to let you improve the sound?  Full details in this new video... https://youtu.be/jb8ujaG8Hro
Kind regards, Steve.
Steve.
www.soundsheavenly.com
JulianJ
Posts 64
JulianJ replied on Wed, Nov 24 2021 9:48 AM
Thank you Steve, for another very informative video! Very, very interesting.
Kind regards,
Julian
JulianJ
Posts 64
Kind regards,
Julian
Dave
Posts 128
Dave replied on Thu, Nov 25 2021 10:19 PM
These are such awesome speakers. I'm on my second pair and they are still my favourite. The first pair I had I played around with the potentiometers and found a good amount of bass... however, just like you say, their "lack of bass" isn't necessarily a bad thing, and it does make them incredibly accurate. My current pair is set to all the factory settings and they are in a small room with low ceilings. Surprisingly they sound perfect even in the small space and I enjoy them very very much. If I didn't have to worry about my neighbours they would be up at higher volumes more often, because their sound fills and vibrates the entire house. They do sound shrieky at high volume of you are standing in front of them but that effect isn't there when you have them on and are moving around other parts of the house.
Razlaw
Posts 4,243
Razlaw replied on Fri, Nov 26 2021 12:46 AM
Great video, and great speakers. I even frequently find myself listening to my 1s instead of my 50s. I know that is bizarre. Somehow, I find the 1s more relaxing to listen to.
Beolab 50s Beolab 9s Beolab 12-3s Beolab 1s Beolab 6000s 2 pairs Beolab 4000s Beovision 7-55 Beovision 10-40 Beoplay V1 32 inch Beovision Avant 32 inch Beosound 1 (CD player) Beosound 3000 Beosound 5 Core Essence MKII Beoplay M5
Geoff Martin
Struer, Denmark
Posts 656
Just a heads-up: these potentiometers are there for making adjustments on the production line for differences in amplifier gains and driver sensitivities. The adjustments were made based on measurements of the loudspeaker's response differences relative to the intended sound design so that they match the specification.
This doesn't mean that you shouldn't adjust them to suit your tastes - they're your loudspeakers.
However, if you ever sell them, it would be polite to return the pots to their original setting, otherwise you're not selling a pair of Beloab 1s.
Cheers
-geoff
Beouser66
Posts 38
Beouser66 replied on Fri, Nov 26 2021 7:19 AM
This kind of ”secret control” are that fore a reason..
and you have them on all older active b&o speaker to calibrate drivers ( one driver is not equal to another)
not to adjust sound for preferens
as Geoff martin say it’s your speaker but can you get it back then you sell them?
Posts 2,092
Geoff Martin:
Cheers
-geoff
Hi Geoff,
I agree entirely.  For this reason, I made sure to emphasise in my video that it is important to carefully record the settings for each individual speaker so that they can be returned to factory settings at any point.
If the original settings become forgotten, then all is not lost.  However, things do become a little trickier, as you would need to remove each speaker driver, note the calibration markings and look these up in the chart within the Beolab 1 Service Manual to obtain the correct adjustment settings.  Hence, it is always best to note the factory settings on the speaker for easy reference!
Steve.
Page 1 of 1 (8 items) | RSS
