beovision 3.......sky hd????
Answered (Not Verified) This post has 0 verified answers | 4 Replies | 0 Followers
bramble
bramble posted on Sun, Feb 24 2013 12:42 PM
I have had to update my failing old sky+ box, and sky have gave me an hd + box, now my bv3 will only scroll thru there menu etc , and i am unable to use digits to choose a channel i.e press  301 and  nothing happens ......is that me now having to collect remotes again or is there a fix........ah nuts
Beovision 7 40 mk 5 ,beovision 6x3,   beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2,  5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
Langleyav
Windsor UK
Silver Member
Suggested by Langleyav
In the BV3 set up for decoders, there are 2 Skyboxes listed.
12 Sky Digital
47 Pace Sky+
Could be you need to change to the other listed decoder.
I have just installed a Sky multi-room HD box which works well on No47
Ron
Seanie_230
UK
HI there
you need to get the PUC control for SKY HD they are different than the SKY+ box
im not sure the BV3 has the PUC for SKY HD
look for thompson HD in your list.
Your dealer will be able to tell you if your TV can be flashed with a new PUC or if it has a chip - you might be able to have a HD PUC installed but it depends on the method of updating and if it was availible.
as a last resort you could use a lintronic
BLGW - Rekindling the love of ML
bramble
Have done it ....... control with all function, pace sky+....works...now to bin the sky+ buttons
bramble
Page 1 of 1 (5 items) | RSS
