Clearance on Beogram 4500
Not Answered This post has 0 verified answers | 3 Replies | 1 Follower
BeoJosh
BeoJosh posted on Thu, Oct 21 2021 7:44 PM
For any Beogram 4500 owners out there, could you tell me the clearance height (from the tabletop/surface to the front bottom edge of the turntable) of the front lip of the turntable? Looking to possibly add another Beogram that would live on a pull-out shelf, and want to make sure it'll fit. Given the height of the shelf handle, I think the design of the 4500 might be my best option. Thanks!
Beovision Harmony 77, Beovision Harmony 65 x2, Beovision Contour 48, LG GX 65/Beosound Stage/STB Stand
Beolab 50s, Beolab 28s, Beolab 18s x3, Beolab 19, Beoplay A9, Beosound Edge, Beosound 2 x2, Beosound 1 x2, Beosound Level x2, Beosound Core x2, Beoplay M3, Beosound 9000, Beogram TX2, Beogram 6500 White Edition, 4000c (on order), Beoremote One x8, Beoremote Halo x3, BLC NL/ML
Beoplay H95 x3, Beoplay EQ x2, Beoplay E8, Beoplay E8 Sport, Beosound A1 x2
Rolf 2
Germany
Rolf 2 replied on Thu, Oct 21 2021 9:43 PM
Hi, mine is measured at a height of exactly 26 cm, hope this helps.
Kind regards,
Rolf
Rolf 2
Germany
Rolf 2 replied on Thu, Oct 21 2021 9:58 PM
Checked the BG 9500 which is measured at the same height.
Kind regards,
Rolf
BeoJosh
BeoJosh replied on Thu, Oct 21 2021 10:37 PM
Thanks so much! That’d work perfectly.
Page 1 of 1 (4 items) | RSS
