Spotify Connect arrives in alot of B&O products
Not Answered This post has 0 verified answers | 46 Replies | 1 Follower
baronvejrup
baronvejrup posted on Fri, Oct 15 2021 2:19 PM
BOTF #shorts Bang & Olufsen just released new software update Spotify Connect to many speakers
https://youtu.be/zPUfAzz_iTg
Find me on YouTube : Bang & Olufsen Teknisk Forum : https://www.youtube.com/c/BangOlufsenTekniskForum
Hiort
Sweden
Hiort replied on Thu, Oct 21 2021 7:58 AM
trackbeo:
Minor app bug: Product Settings/About still reports the old 1.11 software version #, even though Product Settings/Software shows the new 1.12 version #.  App must be storing it somewhere, because the device's webserver reports the correct new # too.
Strange. For me the app "about" page show the correct SW version for the Beosound 1 GVA.
crossbytje
I'm a bit confused.
The Spotify connect functionality works on my M3's. I received the updates yesterday.
As it appears, Spotify does not allow you to play to more than one device simultaneously (which is apparently standard behavior). That was previously possible if I selected airplay from my phone, but that required the phone app to be running and draining battery. Also L/R channel separation was impossible. Then came the Chromecast stereo pairing, which allowed to use my pair as a stereo pair. I thought that this also required my phone to be actually streaming constantly, but as I tested today, I can shut down all my devices running Spotify (phone and computer) and my stereo pair keeps playing uninterrupted!
I can also use my BeoRemote One, the B&O app, or any other way to skip tracks, play/pause, volume control etc.
Makes me think, what were we waiting for? Where is the added value of Spotify Connect if it already worked through the Chromecast built-in?
Beolit 12 - Beolab 4 pc (dead now) - Beoplay H5 - Beolab 9 - BeoRemote One BT - Beoplay M3
Sandyb
Sandyb replied on Thu, Oct 21 2021 10:03 AM
Chromecast works differently to Airplay.
With Airplay you are streaming (from the cloud) to your phone and your phone sends that on to the Airplay speaker. So yes, reliant on the phone being up and running.
With Chromecast your phone is just acting as a remote (i.e prompt) to tell the CC speaker to get the music itself from the cloud. So once you have done that, you can shut your phone down if you want.
Apologies if you knew all of that.
As for the differences between Spotify Connect and Chromecast, I'm not sure.  Of course Spotify Connect speakers dont need setting up in the Google Home app, as they identify themselves to the Spotify app on your phone automatically.
There also be a benefit when it comes to gapless playback - Spotify Connect streams will do gapless I think, whereas Chromecast streams do not.  Other forum members may confirm, or not, but I believe that to be the case.
But otherwise, yes I dont have a substantive reason why Spotify Connect is that different to Chromecasting.
ebnrob
UK
ebnrob replied on Thu, Oct 21 2021 10:50 AM
crossbytje:
The b&o 'touch to join' feature for multiroom playback works with spotify connect and doesn't with chromecast.
Millemissen
Flensborg, Denmark
crossbytje:
I'm a bit confused.
What you describe as the behaviour for using AP2 or CC with the B&O (and other non-B&O) devices is correct - as also Sandyb writes.
This is well-known and used amongst B&O-users.
What makes the use of Spotify Connect (with the supported B&O devices…..which seems to be all now) different, is the possibility to multiroom the stream via Beolink.
Whereas you - with CC - will have to make static groups in order to have multiroom and - with AP2 - will have to add and disconnect the devices outside the Bang & Olufsen app, you can do this within the Bang & Olufsen app, via the beoremote or directly on the devices (Join). And you can add/disconnect the devices ad libitum rather easy, if you need to.
Yes, you can do beolink-multiroom Spotify using AP. But at least in my setup it does not work as well as with the Connect version - and Android users can not use AirPlay. I wonder if there is metadata/cover showing on a Harmony/Eclipse (?).
The only thing you must do - which is the difference to using the built-in Deezer - is that you will have to choose your music in the Spotify app……once that is done you have the full beolink experience just like with radio listening etc.
In case you - like me - have one or more BV’s from the BV11/AVANT 1. Gen/V1 generation, these also can be a part of the listening experience….just like with e.g. an A9.
Some people like the UI of Spotify more than the UI of the built-in Dezzer (in the B&O app) - however, that may seem a personal choice.
AND - if that is as important for you as for me - Spotify Connect (and Spotfy Connect/NL) allows for gapless playback.
Sandyb already mentioned that - for me that has always been a main reason to stick to Spotify (try listening to a Pink Floyd album from Spotify either via AP or CC….that is not what was meant with these album).
So the added value is, that you can stay within the Bang & Olufsen experience  -  this might be trivial to some users, but it certainly matters to those users, who use beolink multiroom……and prefer Spotify as their music streaming service.
(Looking forward to the day, when Spotify starts their long anounced HIFI/lossless version).
All in all….there is not really anything new about it - apart from the fact that now a lot more B&O devices have support for Spotify Connect built-in.
Whether someone will benifit or not, will heavily depend on his/her setup and his/her user behaviour….maybe that someone likes to engage Hey Siri or Hey Goole when listening to music!
To showcase what the difference is (when you prefer the B&O experience) please look at this picture from my setup.
One showing a Spotify stream via Connect and the options to add/disconnect my devices - the other showing the same Spotify stream via CC….no possibility to add the devices directly there.
beolion
beolion replied on Thu, Oct 21 2021 11:48 AM
Very well written MM. Its for sure very clear for me now.
crossbytje
Aha, that makes it very clear, thank you for explaining!
In my setup, I simply don't have enough Beolink devices to notice the difference, or benefit from this added functionality. But if you do, well, it clearly makes life easier to get hassle-free multiroom sound. (That join button on the device is key!)
I kind of have to rely on AirPlay, as that's the only thing my old Beolit 12 accepts.
trackbeo
Hiort:
trackbeo:
Aaaand... a couple days later it's up-to-date!  Many days of DLNA play/pause (and trying out Spotify Connect of course!!! :-) and hard app-exit and iPad power-down made no change.  But just recently I switched sound profiles, created a new sound profile, and deleted it.  So some data storage got re-cached/cleared probably.
Also the app has race conditions with this device, where if you switch states too fast,  it starts playing but the right-pointing triangle/arrow icon stays an arrow.  So now you press the play button to *pause*!  Press it again to play, and like normal it switches to the two-bars pause icon, as it should. Staying in sync is unrelated to the version # bug, of course, but there are multiple little mistakes in the way the app interacts with this particular device's post-1.7 firmware's status reports.  The DLNA play counter failing to update from 0:00 still ticks me off the worst...  I am really pleased that Spotify Connect is working now -- when B&O finally breaks DLNA playback completely, I will be able to rely on a Spotify auto-playlist of my choosing/shaping.  A good 21st-century work-around to maintaining a 20th-century music library!
steve1977
I posted this in another thread, but it may be better suited here.
Can I make "permanent" groups within the B&O APP. And then use spotifyconnect to play to any of the speakers within this group to play to the group.
And is it possible to distribute a GVA Spotify stream to other NL speakers?
Frederik
Belgium
steve1977:
Currently you can only do this if you have the Beoliving Intelligence hub. I agree that it would be nice to have a speakers group functionality natively in the B&O app, also to have volume control via the BR One or Halo for multiple speakers together.
steve1977:
I don't think so.
Mikael
Denmark
Mikael replied on Tue, Nov 30 2021 9:25 AM
steve1977:
Sadly no, and I don't expect this to change.
When you start a Spotify stream through GVA it will always start the stream as a Chromecast stream. It is not possible to use Multiroom with a Chromecast stream.
For this to change we need either Google to allow GVA to start a Spotify Connect stream (Never going to happen, as this is a direct competitor to their own Chromecast), or Google should allow Chromecast to be used in Multiroom. The latter could be the way forward, but there might be technical limitations at play here. Chromecast can not extend to more speakers without using a pre-defined group of speakers at the moment.
So basically what you are seeking is a mix of the Chromecast and Multiroom functionality. For this to happen Google needs to change things, and B&O needs to implement it. Not something I see happening anytime soon, primarily because B&O doesn't have the power to make Google change.
Beovision Eclipse gen2 (GX) w/ floorstand, Beolab 14.2, 4 speaker Shape and ATV4/Chromecast.
Beoplay A9mk4 GVA, Beosound 1 GVA, H2, H3, H8, E6, Beoplay EQ
mbolo01
Louannec - France
Talking about product firmware update, did the Core finally receive an update at the end of the day?
I have seen posts about a Core update being rolled out at the same time than the other products when Spotify connect was activated on some of them, I have seen about posts related to bugs introduced by the Core update that was withdrawn at some point, and I have seen an update available on mine, that I didn't install, but since I don't see anymore an update available for my Core which is still at version 1.11.46587
Feedback appreciated.
Raeven
Raeven replied on Tue, Nov 30 2021 9:49 AM
My 3 core's are now at 1.12.47460
mbolo01
Louannec - France
mbolo01 replied on Tue, Nov 30 2021 10:58 AM
Raeven:
Many thanks, I'll open a ticket with B&O to understand why no update is available for mine.
Mikael
Denmark
Mikael replied on Tue, Nov 30 2021 11:28 AM
I manually updated mine to 1.12.47108 October 14th, from the same version you have.
Got an automatic update to 1.12.47640 on October 26th.
Have you tried updating using the "old" web interface in the web?
Page 3 of 4 (47 items) < Previous 1 2 3 4 Next > | RSS
