Tunein don’t start on Essence MK1
liviu_o
Posts 154
liviu_o Posted: Sun, Sep 26 2021 11:44 PM
Hi all!
Some weeks ago my MK1 BO Essence stoped to start tunein form remote.
The only way to play a radiostation from Tunein is to start it on my phone and then to use Airplay.
I tried to reset and reinstall Essence in the BO app but without any results.
Can someone please help me?
Thanks!
lob4475
Posts 11
lob4475 replied on Tue, Sep 28 2021 4:02 PM
It is a know problem.
I am in contact with Bang & Olufsen support but so far without a solution.
You can probably play some stations on TuneIn (for instance SomaFM Secret Agent works fine for me), while others do not work at all
I have contacted TuneIn support as well, but so far with no results (they say that there have been no changes to the streams i normally use since 2017)
All in all the underlying technical problem is - to my knowledge - not yet known.
Best,
Ben
Page 1 of 1 (2 items) | RSS
