Beomaster 7000 Audio Output
Not Answered This post has 0 verified answers | 18 Replies | 1 Follower
fizz
fizz posted on Sat, Sep 25 2021 5:43 PM
I have sound through my headphone jack but my Beolabs are not powering on. Where should I begin my search for a solution?
Thanks!
Millemissen
Flensborg, Denmark
You could begin telling us which Beolabs you have and which Powerlink cables you use.
fizz
fizz replied on Sun, Sep 26 2021 4:09 PM
My apologies.
I have 4 Beolab 8000's and purchased new power link cables from a supplier in the UK. I forget the name.
The system was working great one day. We had a brown out, the unit is connected to a UPS with surge protection, and the unit was not in use at the time.
The next day no sound.
fizz
My apologies.
Millemissen
Flensborg, Denmark
Sure hope that the ‘brown out’ was a power failure, and not……. ;-))))
Did you try out the Beolabs one at a time, did you try changing cables?
Seems to be something in the BM7000, that needs to be checked.
Do you have any opportunity to try the speakers on another beomaster/-sound/-vision?
To borrow one or?
Schletti82
This is 99% not a fault from you speakers.
The 7000/6500/5500 have a relais switching for headphone and speaker Output.
It is a common fail that this Relais is not working properly.
First you can Try is to Plug and unplug your headphones a des times.
is the relay clicking. Maybe the Sound to you speakers is back.
if not, open up your 7000. the relay sits one the left from Front on a small extra Platine put on top of another Platine.
the relay you can see Directly in Front of the speaker Outputs.
open ist up, clean the contacts or better replace that one and everything will work as if should
Guy
Buckinghamshire
Guy replied on Tue, Sep 28 2021 11:38 AM
Schletti82:
I could be wrong but I think that the mute relay only switches the speaker 1 (passive) speaker outputs.   However, the signal that operates the relay is provided by the circuit that also applies power to Powerlink pin 4.
Hence I would suspect the headphone socket, specifically the mechanical contact that supplies the trigger voltage to both the aforementioned relay and powerlink pin 4.
If you have some passive speakers you could try connecting them to the speaker 2 outputs, which are not affected by the mute relay.
(For the sets with 1/4" headphone sockets, this problem was often caused by people leaving a 3.5mm headphone adaptor in the socket, but as the BM7000 already has a 3.5mm socket I doubt that this is the problem here!)
fizz
fizz replied on Fri, Oct 1 2021 3:42 AM
No clicking of a relay when inserting and removing the 3.5mm headphone jack.
Do you have a picture of the relay location?
fizz
fizz replied on Fri, Oct 1 2021 10:12 PM
Can you tell me which one is the relay? I am assuming it is the black one with the 204 sticker.
Lonnie
Lonnie replied on Fri, Oct 1 2021 11:35 PM
Yes that is correct, it sits on PCB 7 which is piggybacked onto PCB 3.
Regards
Lonnie
Guy
Buckinghamshire
Guy replied on Sat, Oct 2 2021 10:43 AM
fizz:
I suggest that you check the circuit diagram before playing around with the relay.  The relay does not turn the PL outputs on/off.  As mentioned before, the contact breaker in the headphone socket could well be the culprit - it is directly connected to PL pin 4.
fizz
fizz replied on Mon, Oct 4 2021 8:58 PM
Thank you for that info.
Since it was working one day then not the next (even without using headphones) would you still think it is the contact breaker in the socket?
Guy
Buckinghamshire
Guy replied on Mon, Oct 4 2021 9:15 PM
fizz:
Not necessarily, but I would check it before looking at the relay.
By the way, do the Beolabs still each show a red standby light?
fizz
fizz replied on Mon, Oct 4 2021 9:35 PM
Yes, Beolabs are all showing red.
Guy
Buckinghamshire
Guy replied on Mon, Oct 4 2021 9:48 PM
fizz:
And have you tried MM's suggestions, swapping around cables etc?
Also have you tried passive speakers to the Spkr 1 and 2 sockets?
Page 1 of 2 (19 items) 1 2 Next > | RSS
