Beomaster 4000 - Resistor from power switch to ground
Not Answered This post has 0 verified answers | 2 Replies | 1 Follower
Jeffrey P Brooks
United States
Silver Member
Jeffrey P Brooks posted on Wed, Sep 15 2021 11:27 PM
I am repairing a Beomaster 4000 and just replaced a power switch that I got from Beoparts.  I managed to break the lead to the 3.3 MOhm resistor that lives right by this power switch which is connected from the switch itself (which carries mains voltage) to ground.
I ordered a replacement, but i'm wondering if anyone knows just what the purpose of this is?  The plug isn't polarized, so i don't think it matters which pole on the switch you connect the resistor to, but what does it do?
Thanks!  Jeff
Menahem Yachad
Jerusalem, Israel
IIRC, it's a snubber resistor, designed to shunt off the arc energy created, when breaking contact - ie switching OFF the machine. Those arcs, if not mitigated, destroy the contacts of the switch.
So the resistor prolongs the life of the switch
Check my thread here
https://forum.beoworld.org/forums/p/32196/249376.aspx#249376
Jeffrey P Brooks
United States
Silver Member
Thanks for the pointer, Menahem.  My old switch died a mechanical death (the plastic part with the spring on it that moves the poles on the switch was broken), not a bad contactor death.  I'll have to open the old one up to see how it looks!
Page 1 of 1 (3 items) | RSS
