Beovision 8-32 and Playstation 4
Not Answered This post has 0 verified answers | 2 Replies | 0 Followers
mr_anders_son
sweden
mr_anders_son posted on Mon, Sep 13 2021 4:47 PM
I can not get a picture with HDMI between my Beovision 8-32 and Playstation 4.
Not chromecast either.
Any tips?
It works with another non B&O TV
BeoVision Eclipse 55"...BeoLab 5 FRONT....BeoLab 4000 as REAR....BV5 HD....Beoplay V1-40....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
david656
Silver Member
david656 replied on Mon, Sep 13 2021 11:53 PM
Sadly I don't have a BV8-32 so I'm only guessing with this.
Does your BV8 have the built in HDMI port or are you using a HDMI/DVI converter? Do you have access to a laptop or computer with HDMI out? if you connect a computer to it, does it recognise it as a second/external display? if you look at the display settings it should say if it detects it and might even give you some basic information on the display. This would be a good test to see if the port is picked up.
On the TV itself have you gone through the settings and selected the HDMI port to an appropriate AV source name? DVD maybe or V.Mem.
As I say just some speculative advice above, but thought it was worth trying to help you out.
Thanks,
Bristol based B&O fan with a collection including the following: BC9500, Beogram 9500, Beosystem 3, BeoVision Avant DVD 32, AV9000, Beolab 3500, Beolab 3000s, Beolab 4s, Beolab 6000s, Beovox Pentas, Beovox 3000s.
kallasr
Germany
mr_anders_son:
Try setting the picture quality to 720p fix using your other TV, then try BV 8-32 again.
It has 720p only and does not communicate well with the PS4...
Had the same issue with PS3 in the past.
Ralf
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab Penta 2 (Fronts), Beolab 4000 (Rears) and Beolab 2. Projector: Sony VPL-HW55
Home Office: Beovision 10-40 on STB Bracket wall mount. Beosound 9000 MK3 on horizontal wall bracket driving Beolab 5000 Speakers
Bedroom: Loewe TV with Beolab 6002 and Beolab 11 (all white, wall-mounted)
Page 1 of 1 (3 items) | RSS
