Connecting PC to Beolink Active
Not Answered This post has 0 verified answers | 23 Replies | 0 Followers
Nkhort
Добрый день! Простите за глупый вопрос, я новичок на форуме. Подскажите пожалуйста, как сделать подключения как на картинке? Спасибо
Stan
Chicago-area USA
Stan replied on Tue, Jul 20 2021 5:45 PM
Assuming you have everything in the picture, all you need is a "PC to BL Active" cable which Steve at Sounds Heavenly probably has on hand.  Your b&o dealer might, but I always had problems with them ordering the wrong cable when I did this.  It is NOT the same as an AUX-in cable.
A couple comments:
1)  Your title says "Beolink Passive", but the diagram shows a "Beolink Active".  If you have a Passive it is a different cable (which, again, you can probably get from Steve at Sounds Heavenly).
2)  If you have an Active, then the Active must be connected to a working BeoLink Master (i.e. Beosound or Beovision that supports ML) via MasterLink
3)  If you actually have a Passive, then this can run just fine without a MasterLink master.  However, as the name suggests, the BL Passive supports passive speakers (no built-in amplifier).
Stan
Nkhort
Thank you very much for your reply!  Sorry, I was wrong, I have Biolink Active.  I ordered a wire on eBay, as in the photo.  I was advised this wire
Nkhort
такая система
Stan
Chicago-area USA
Stan replied on Tue, Jul 20 2021 10:27 PM
Looks like you have everything.. although your Active must have an IR receiver.  Now, just hook everything up, and press "PC" on your Beo4 to hear what your phone is playing.  You may need to add the PC command to your remote.  The instructions on how to add additional commands to a Beo4 can be found on the site somewhere (I don't remember myself).  The audio from the cable only plays on the speakers connected to the Active.
Nkhort
Nkhort replied on Tue, Jul 20 2021 10:40 PM
Thank you so much!  I also have an IR receiver, from only the PC command I can’t find it: (Or I’m looking in the wrong place
Nkhort
Nkhort replied on Tue, Jul 20 2021 11:05 PM
Found information "PC"  Beo4 ... It turns out that I have an old version of Beo4 that does not support the "PC" function :(
Thank you so much for responding to me!
Stan
Chicago-area USA
Stan replied on Wed, Jul 21 2021 12:05 AM
On you beo4:
1)  Hold down the red dot button and the LIST button until the screen says "ADD?"
2)  Press OK
3)  Scroll (up/down arrow) through the options until you find "PC"
4)  Press OK
5)  Screen should say "ADDED"
6)  Press LIST repeatedly until the screen shows "PC"
7)  Press OK
8)  Sit back, relax, enjoy music :D
Nkhort
Nkhort replied on Wed, Jul 21 2021 5:03 AM
Thank you so much!  I do so, but there are no PC features on this list.  I read that I have an older Beo4 and do not have a PC function yet :(
https://forum.beoworld.org/forums/p/45348/327903.aspx
stefan
200 miles from Struer
stefan replied on Wed, Jul 21 2021 11:28 AM
Nkhort:
I`m pretty sure, your 5 pin cable (?) in the picture won`t work - the PC socket has a special wiring with pins 2 - 4 - 7 for L-R-GND.
You will find more info in the archived forum.
Hope this helps
Stefan
stefan
stefan replied on Wed, Jul 21 2021 11:31 AM
Nkhort:
Maybe you can manage to press SHIFT (as a LIST function) and STORE (as a hard button...) This will send the same IR code as "PC".
Hope this helps
Stefan
Nkhort
Nkhort replied on Wed, Jul 21 2021 3:25 PM
Thanks, I'll try now)
Nkhort
Nkhort replied on Wed, Jul 21 2021 3:43 PM
You’ll laugh now, but I don’t have a Store button on the remote either :))))
Nkhort
I have the same as in the picture
Guy
Buckinghamshire
Guy replied on Wed, Jul 21 2021 9:56 PM
To check the SW version of your Beo4 remote
Press GO and MENU at the same time then press LIST three times.  What does it say?
Page 1 of 2 (24 items) 1 2 Next > | RSS
