Beogram 5500 won't turn on
Answered (Verified) This post has 1 verified answer | 12 Replies | 2 Followers
baddo
baddo posted on Wed, Feb 13 2013 8:57 PM
Hello all,
So my beogram 5500 won't turn on, for a little while it would turn on but the arm wouldn't move, now hitting the power button does nothing.  The beomaster still turns on and works fine.
I spoke to a local B&O store and they said they could have it repaired with a $90 estimate fee, the actual repair would most likely be in the mid hundreds depending on the issue according to the man I spoke to.  Any ideas of what the issue could be?  I was told that since I can't get it to turn on at all it is most likely an issue with the main board.
Should I try to fix it myself or find a repair man outside of B&O?  I'm in NYC by the way.
Many thanks for the help.
pfroche
Answered (Verified) pfroche replied on Thu, Jun 27 2013 11:24 AM
Verified by pfroche
Hi Menahem
Just saw your response re. tangential-tracking arm issue on Beogram 5500.
In my case, the Play function works, the arm goes up and down and plays the record properly. However, the cartridge does not slide anymore, ultimately leading the reading to stop.
I am kind of scared to carry out your Solenoid Piston Rebuild as it is looks quite daunting for a non-engineer, non-native English speaker.
So, three questions:
- could my problem be resolved with lubrication
- if yes, would you have photos showing exactly what needs lubrication and where
- if I need to carry out the Solenoid Piston Rebuild, do you have additional photos to guide me through the process?
Many thanks in advance for your help,
Patrick
(Dublin, Ireland)
MediaBobNY
Greenwich Village, NYC
You could try Atlantic Systems in Hanover, MA (Paul is the Mgr) - they're cheaper than the NYC repair shops even when cost of shipping is taken into account.  But I think this might be one of those cases where it's more cost efficient to buy a working one off of eBay or Craigslist and selling yours as a parts/repair unit.   Unless of course someone replies to your post with an easy do-it-yourself fix.
Menahem Yachad
Jerusalem, Israel
You have the classic symptom of a failed piston.
Read this for further details - copy and paste the URL in your browser
http://www.condoraudio.com/wp-content/uploads/Projects/BeoGram-4500-Turntable-Restoration-Repair.pdf
pfroche
Verified by pfroche
Hi Menahem
Patrick
(Dublin, Ireland)
Orava
Finland
Orava replied on Thu, Jun 27 2013 11:34 AM
If arm goes at begining of record, plays but does not move foward, it is probably LDR or bulb problem on base of arm assembly. Checking this needs a little disasembling. Not big problem and fixable.
There is threads about this on forum (though, I did not find one now Sad)
Menahem Yachad
Jerusalem, Israel
Hi Patrick,
If the Play function works, the "problem" is not in the piston (PHEW!).
I don''t understand if it "plays the record properly" , then where's the problem?
What do you mean "the cartridge does not slide anymore"?
If you could be more specific about what is happening EXACTLY, I can probably help you, but right now, I really don't understand what's going on!
Menahem
pfroche
Hi Menachem
Many thanks for replying and apologies for the delay in getting back to you as for my fuzzy explanation and improper use of the term cartridge. I'll try and clarify:
- when I press play, the platter starts normally, but neither tone nor detector arms move (with or without a record on the platter)
- the play function continues regardless and the tone arm lowers straight on to the actual deck
- if I manually slide both arms over the record and lower the tone arm, it lands on the record plays the track normally - for a few seconds: as the arms don't move, the tone arm is gradually pulled away from the detector arm until it eventually lifts back up and the play stops.
Hope this makes more sense - and hopefully still does not involve the piston :-)
Looking froward to hearing from you.
Best regards,
Patrick
Menahem Yachad
Jerusalem, Israel
OK, now it is quite clear!
Open up the machine, as per the Service Manual, and look at the back under the tonearm.
Is the white cable secure and tension-ed?
Is the rubber belt on the servo motor OK? That's the small rubber belt, not the large belt which rotates the platter.
Those are the 2 most likely causes of the problem.
joeyboygolf
Ely, Cambridgeshire, UK
It sounds like the carriage is not moving at all so it must be the drive string has become un-attached, probably due to a broken attachment point on the carriage.
Regards Graham
Peter
Earsdon
Peter replied on Tue, Jul 2 2013 9:13 AM
Agree with Graham - seems to happen more often due to aging plastic I presume.
Peter
pfroche
pfroche replied on Thu, Jul 11 2013 10:25 PM
Hello Menahem
Many, many thanks for your reply and again apologies for my late response - we have now started our annual family trip to visit the relatives et al, so am away from the dear Beogram 5500 until early August. But I will definitely check this out when I'm back and let you know the results.
All the best.
Patrick
pfroche
pfroche replied on Thu, Jul 11 2013 10:26 PM
Hello Joey
All the best.
Patrick
pfroche
Hello Peter
All the best.
Patrick
Page 1 of 1 (13 items) | RSS
