Beogram 2000 Tonearm Height.
Not Answered This post has 0 verified answers | 5 Replies | 1 Follower
seesalt
seesalt posted on Sat, Jun 5 2021 2:59 PM
Let's get right to it:
My tonearm wont go down properly to reach the record.
Now, i have looked inside the manual Where it states you van set the tonearm by adjusting a screw as shown:
The Problem is, there is no L screw shown in the manual.
Does anyone now how to set the hight properly cause i can't seem to find a way to adjust it.
FYI it's the Beogram 2000 5821
Dillen
Copenhagen / Denmark
Most likely the lifting mechanism has broken at the tonearm base.
It's quite common.
seesalt
Any way to fix this or is this a lost cause?
Dillen
Dillen replied on Thu, Jun 10 2021 6:33 AM
Is it broken?
seesalt
seesalt replied on Thu, Jun 10 2021 10:05 PM
 I can't really tell if it's broken or not.  I have no idea what to look for.
There is obviously something wrong. But then I Have to take it apart to see I think
Al I can say is that before it was in this state, maybe a couple hours before the picture, i probably bumped into it and now it won't get any lower than You see above.
ProGram
59269 Beckum, Germany
You may have to disassemble the tonearm. I've had both broken hinges, which I replaced with some aluminium. It works quite well.
Page 1 of 1 (6 items) | RSS
