Beolab 11 - Weakness
Not Answered This post has 0 verified answers | 5 Replies | 1 Follower
Pindsen
Denmark
Pindsen posted on Tue, Jun 1 2021 6:31 PM
To my knowledge the Beolab 11 was only sold in a 4-5 years period (2010-2014).
Does it have any kind of weaknesses or bad design to be aware of if you gonna buy one now?
Was it upgraded in a Mark II version?
/Pindsen
kuyttendaele
Pindsen:
To my knowledge the Beolab 11 was only sold in a 4-5 years period (2010-2014). Does it have any kind of weaknesses or bad design to be aware of if you gonna buy one now?
/Pindsen
Have it been using since it came out with my BL8000’s. The BL11 does not product earthquakes but does add bass where needed to BL4/4000/6000/8000. Useless with BL Penta’s/1/9
Karel.
Steffen
Denmark
kuyttendaele:
Pindsen:
/Pindsen
Karel.
I would say, that it DOES add a bit of bass to the Beolab 1's.
As some may have seen here on Beoworld, I bought a pair of BL 1's for my home-bar last year - and they have less bass than the Penta's - so last month I bought a BL 11. The BL 1's sound better with the sub, that just gives them that little extra.
However, it does not add anything to the Penta's (or the BL9's).
kuyttendaele
Steffen:
That's soooo strange. The BL1 & 11 have the same diameter for the woofer "16.5cm) but the BL1's amp is way more powerfull: 450w vs 200 w
Pindsen
Denmark
But does the design have any weaknesses?. As an example the bas units in BL6000 MK1 gets weak over time, does the BL11 have similar issues or others?
/Pindsen
Millemissen
Flensborg, Denmark
All electronic fail over time.
The BL11 can fail too.
Unfortunately you mostly have to exchange the chassis completely....which may be expensive.
I can’t say how often that happens - also not if any particular serialnumber (indicates the age) is more affected than another.
I enjoy how my 2 BL11’s behave.
As an addition to the right speakers and proper set up (in particular if you use the bas management of a BSys4-based tv) they do a good job.
Don’t expect earthshaking bas - there are other speakers for that.
Page 1 of 1 (6 items) | RSS
