No app connection to my BeoLab 50s
Not Answered This post has 0 verified answers | 7 Replies | 1 Follower
Lasse K.
Lasse K. posted on Thu, May 27 2021 9:52 PM
Hi there,
I just cannot connect to my Beolab 50's anymore.
The app says it is waking the BL50's up but I cannot get to them.
When I connect through the "products" entry, I get an error saying "We cannot reach your product". Even when they are playing.
How can I reconnect without resetting everything?
Problem has been posted before but I couldn´t find the answer. Could anybody help me?
Lasse
MaxH
MaxH replied on Fri, May 28 2021 9:30 AM
First thing to try is to power cycle everything . . .
Lasse K.
Sure thing! Didn't work, though ...
Lasse K.
Mikipidia
Second thing, is get an ethernet cable from your router to the master speaker. If there is any network config issue you can fix it while wired.
New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0
mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Lasse K.
Tanks! Will give it a try tonight.
Lasse K.
Lasse K. replied on Sun, May 30 2021 10:36 PM
Tried it tonight. Didn’t work, unfortunately. When BL master is wired to LAN it indicates a strong connection (status LED network solid white). But in this state I can’t find it on WLAN and access through my iphone. If I disonnect the LAN cable and do a network reset I can find the BLs on my phone. (At least 6 times out of 10, that is.) The the app sometimes finds the BLs and I can enter wireless setup. Sometimes setup even seems to be successful but when I try to access my BLs - product cannot be found. It‘s just so damn frustrating. Spent 6 hours now on this. Don‘t see what I could change or try different. I‘ve done a complete factory reset now a couple of times but still haven‘t resolved it. (So now I even lost my calibration settings.) Connection behaviour just seems so erratic. No clue what to do ...
Mikipidia
Are you sure it's the speakers at this point? Because, correct me if I am wrong, but even when wired the app doesn't connect 4 out of 10 times???
btw, is everything up to date software wise? speakers too? which SW are they running?
Page 1 of 1 (8 items) | RSS
