Halo 6+ months on?
Not Answered This post has 0 verified answers | 19 Replies | 2 Followers
seethroughyou
UK
seethroughyou posted on Wed, May 26 2021 3:54 PM
What do members make of the Halo a few months on? Hoping to view it again soon.
Happy you bought it?
What new things can it do now?
What negatives have you identified?
Present: BL90, Beosound Moment, Beosound Core, BL6000, Beogram CD7000, Beogram 7000, BS Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, Beocenter 2, Beosound 5, BV5, BV4-50, BV4-65, Beosystem 3, BL3, DVD1, Beoremote 4.
TWG
TWG replied on Sat, Jun 12 2021 9:31 AM
any new functions?
Is the volume wheel only for volume control or does it allow scrolling through lists / menu items? Like a gigantic jog dial, that would be a great idea for nowadays big music libraries.
Curly
FL, USA
Curly replied on Mon, Jun 21 2021 4:07 PM
For those familiar with Halo operation, two questions:
1. From Halo directly, can a user initiate the “Timer” function? For clarity, this is the function within the B&O app that allows a user to tell systems, among other things, “Go to Standby after x minutes.” (I use this to listen to music as I fall asleep and set my bedroom system to turn off automatically after 10min when I’m asleep.)
2. From the Halo directly, can a user manipulate the “Alarm” function for a given device as it operates within the B&O app?
Thank you!
Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Essence Remote
Previously: BeoSound 1 non-GVA
Curly
FL, USA
Curly replied on Sun, Aug 1 2021 2:50 PM
Just thought I’d give this a bump again in case anyone has familiarity with the above. :)
BrianP
It’s a no to both questions, unfortunately. No alarm/timer can be controlled direct from the Halo.
Curly
FL, USA
Curly replied on Mon, Aug 2 2021 6:39 PM
Huge thanks, Brian!
Big bummer. Seems like good functionality to have…
Page 2 of 2 (20 items) < Previous 1 2 | RSS
