Apple TV 4, 4K; and Beovision 14
Not Answered This post has 0 verified answers | 7 Replies | 1 Follower
Aussie Michael
Melbourne, AU
Aussie Michael posted on Sat, May 15 2021 11:45 AM
Hi
I'm using the latest PUC the ATV 4 from IOS 13, however when i turn off the TV the Apple TV doesn't.
I have tried the > LIST > power function but that doesn't work
So i have to click > Settings> Power off the Apple TV then press the power button on the BeoRemote One to turn it off.
Does anyone else have a solution?
I have tried long press of each of the coloured buttons to see if the menus that come up with the Apple TV remote, but to no luck
Are there any other short cuts?
Stoobietoo
Exeter, Devon, UK
in the connections menu, when you set up and choose the PUC, my older TV has 4 choices
Off at source change
Off at TV standby
Always on
Manual control
Not sure if your TV has those options.
Stoobie
Aussie Michael
Melbourne, AU
Thanks for your reply, I believe I chose
Off at standby
As that is the default one i always pick
Millemissen
Flensborg, Denmark
ONLINE
Why not just set the ATV to go to sleep after 15 minutes.
Aussie Michael
Melbourne, AU
Or alternatively why not the PUC turn off the ATV?
I don't think there is an option to turn off the ATV after 15 mins, it's later than that.  It's in a bedroom and the light is annoying.
beoaus
beoaus replied on Sun, May 16 2021 12:20 PM
Hello,
Choose the “manual” setting for a reliable result. Best of a bad bunch.
Cheers Beoaus.
Aussie Michael
Melbourne, AU
Thanks beoaus
ScottMacK
Australia
I have it set to turn itself off after some number of hours. It can’t be too short or it turns itself off if you pause a show and walk away for longer than you expected. Plus, the screen savers are quite nice.
cheers
Page 1 of 1 (8 items) | RSS
