Beovision 11 Motorized Wall Bracket, not returning to standby after sleeping
Answered (Verified) This post has 1 verified answer | 3 Replies | 1 Follower
mobilett
mobilett posted on Thu, May 13 2021 11:41 PM
Hello,
I have the Motorized wall bracket (on my bv11-40) configured for 0 degrees at standby and 45 degrees when On video mode. When I use the remote to turn it off (standby mode), it returns to the standby 0 degrees position. However, when the TV goes to sleep by itself (after Apple TV goes to sleep or TV sleeps), it doesn't return to the standby position. When this happens, when I press the standby button on the remote, the red light in the upper right corner flashes red. If I hold the standby button, the tv will then return to the standby position.
How can I configure it to return to the standby position automatically?
Beouser66
Verified by mobilett
Hi
you can’t !  this is a safety reason that tv only turn stand then you turn of with remote
if tv is going standby remotely (by Other sources or link rooms) the stand not moves
Beouser66
Hi
mobilett
Thank you! Do you know if there's any way to change this behaviour?
Beouser66
No
Page 1 of 1 (4 items) | RSS
