Some buttons of Beo4 still working, others not
Not Answered This post has 0 verified answers | 8 Replies | 1 Follower
tjeerd
tjeerd posted on Thu, May 6 2021 1:32 PM
I have a Beo4 which seems to be broken.
This is what it does:
  • CD, V TAPE, A TAPE, 7, 9, 4, 6, 1, 3 are working: Beolab 2000 or Beovision MX 2000 I have responds
  • SAT seem to be working: I see infra red signal with a camera, but have no device to test with.
  • OFF (red dot): does give infra red signal, Beolab light blinks, but does not turn off; Beovision goes back to the previous channel.
  • LIST does not seem to work, but pressing OFF and LIST together shows CONFIG? On the display, but then it does not respond to other inputs (need to remove batteries before any of the functionality described above works again).
  • Other buttons do not give infra red signal or change the display.
  • When putting in the battery it shows TV on display. Buttons as described above work to control the Beovision, but as soon as it is an other mode it cannot be set back into TV.
I have taken it apart, this is how it looks:
Tought I give it a shot here, maybe someone has an idea.
Guy
Buckinghamshire
Guy replied on Thu, May 6 2021 1:40 PM
Hi and welcome to the forum!
Unfortunately your picture does not show.
With just some of the buttons working it sounds like a problem with the contact foil under the keypad.  I have posted about this here: https://forum.beoworld.org/forums/p/40244/298810.aspx#298810
According to the service manual the faulty buttons that you describe are grouped such that a couple of breaks, or misalignment of the foil could also give the symptoms that you describe.  Hopefully the linked thread will enable you to investigate and fix the problem.
tjeerd
Thanks for the tip.
I removed the clip and used a small brush to clean between the contacts on the foil and the PCB. That helped to get some more buttons working. Might need to look for a replacement foil then to get them all working.
Guy
Buckinghamshire
Guy replied on Fri, May 7 2021 5:55 AM
Yes definitely worth replacing the foil. This has that added advantage of making the Beo4 feel much ‘newer’ to operate as all the buttons will feel more positive.
L Spad
Brighton
I’ve previously repaired broken foil tracks on these using thin strips of tin foil. It’s very fiddly to do but I’ve been successful on two remotes. Are replacement foils still available- would save me some time if any of my others go wrong!
Guy
Buckinghamshire
Guy replied on Fri, May 7 2021 8:23 AM
L Spad :
I have bought them from here a couple of years ago - about £15 each: https://www.avaservices.co.uk/
tjeerd
tjeerd replied on Fri, May 7 2021 10:28 PM
How does this work exactly?
tjeerd
tjeerd
tjeerd replied on Fri, May 7 2021 10:32 PM
L Spad :
How does such a broken foil track repair work?
Page 1 of 1 (9 items) | RSS
