Beocenter 2500 with Beolab 3
Not Answered This post has 0 verified answers | 4 Replies | 0 Followers
Amigo799
Kiev , Ukraine
Amigo799 posted on Wed, May 5 2021 7:54 AM
Hello, Beofuns. Need yours advice. After a recent purchase Beolab 3 I try to connect them to Beocenter 2500. After starting playback the glass doors is open and don't close. ) When Beocenter was connected to Beolab 2500 everything was fine. Then I connect BL3 to Ouverture and and everything is fine too - I mean that the glass doors is close after a few seconds. I think that all this has something to do with the Powerlink MK 3 cable ?
Beosound 9000 + Beolab 8000, Beosound Century, Beocenter  2500 + Beolab 2500,  Beosound 6, Beoplay H6, Beoplay H6 (2-го поколения), Beoplay H8, Beoplay H9, Beoplay E8
CB
> You are Here <
CB replied on Wed, May 5 2021 8:48 AM
Hi
This is weird Erm..
And what if you plug in the BL2500 now?
Amigo799
Kiev , Ukraine
Everything works fine with BL 2500 . I think it has something to do with the cable -  BL3 with Powerlink MK3 vs MK1 for BL 2500.
Guy
Buckinghamshire
ONLINE
Guy replied on Wed, May 5 2021 9:38 AM
Have a look at this thread: https://archivedforum.beoworld.org/forums/p/32921/268304.aspx#268304
In short, users have noticed some sort of incompatibility between BC2300 (similar to 2500) doors and the BL3 speakers.  I think that there may be more threads on this issue but I can't find them.
Try moving the speakers further away from the BC2500. Or try Mk3 Powerlink cables.
Amigo799
Kiev , Ukraine
You "re right , the same problem.
I used with BL3 exactly Mk 3 Powerlink Cables and think that the problem is related with ground the digital amps in BL 3 , may be BC2500 not designed for this ground ?
Page 1 of 1 (5 items) | RSS
