Beosystem and BV 11 in same room using same Beolab 9 speakers
Not Answered This post has 0 verified answers | 20 Replies | 2 Followers
altist
altist posted on Sun, May 2 2021 8:24 PM
Good evening.
  I have a beosystem 6500 and a BV11 set up in front of me and they both use the same Beolab 9 speakers. Can I set the options via Beo 4 so that the TV command for the BV11 doesn't turn on the Aux connection on the Beomaster 6500? I cant find the answer easily at the present time. I'm not using the Beo4 to control the Beosystem as I have a Beolink 1000,MCP6500 and Beolink 7000 to do that,...overkill I know! Thank you for any help that anyone can offer...the TV is in V-Opt 2 but not sure what the Beosystem is in at present.
stefan
200 miles from Struer
stefan replied on Mon, May 3 2021 10:36 AM
Assuming you are using a BL converter 1611 and a BL ML/NL converter between BV11 and BS6500 and your BL9s are connected to BV11, set BS6500 to A.OPT 0 and BV11 (ML/NL converter) to videomaster V.OPT 2.
Stefan
altist
Hi Stefan,
  Thank you for your reply. Im not using any Beolinks between the Beomaster and the BV11. I have the speakers connected by power link from the Beomaster to one of the two power link inputs on BL 9 and then the BV11 to the other powerlink input on the speaker. The problem is the pressing of TV controls on Beo 4 is picked up by the Beomaster as AUX.
Carolpa
ONLINE
altist:
Hi Stefan,
Your setup isn't conform specs. So three options: 1) make the setup conform specs or 2) learn to live with it or 3) put the Beomaster behind doors in a cupboard or in another room.
ad 2) & 3)and hopefully the BL9's will have a long live
Guy
Buckinghamshire
Guy replied on Mon, May 3 2021 5:32 PM
I you don't want to use a converter such as that mentioned by stefan, then in order to 'share' your speakers between the TV and Beosystem, use a powerlink switch such as this: https://shop.oneremote.dk/shop/69067-powerlink-switch/4162-powerlink-speaker-switch/
And then set your BV11 to V.OPT 1 and your BS6500 to A.OPT 1.
altist
Carolpa
I suspected it wasn’t going to be easy, so thank you for the advice and possible solutions.
Guy thank you for that suggestion. I might well go with it as it solves the problem for me in one easy step.
Carolpa
ONLINE
Guy:
Nice solution, unknown to me.
Guy:
if both have an AUX source both would start anyway, because they don't communicate with each other........ so the options do not matter.
But thinking about it: what is the difficulty with the A.AUX command to a BV11 at all? If it is just the BV11 and nothing else, the BV11 shouldn't start.
altist
Hi carolpa
It does seem a very neat solution I think I may have confused you re the Aux appearing. This happens on the Beomaster when I press the tv,Dtv or vmem on the Beo4 that control the tv. I have apple on the Dtv and the inbuilt hard drive on vmem so at least three buttons initiate this Aux appearing.
I’m very grateful to everyone for their advice and possible solutions. Beoworld is a mine of information freely given and that’s a rare freebie in this world! Thank you.
stefan
Guy:
Get the oneremote powerlink switch - they are great - I have two of them in linkrooms to integrate local audiosystems with the main system.
And please, disconnect your powerlink solution - if both systems, BS6500 and BV11 are activated it may (will) result in hum and maybe damage.
Stefan
altist
Thank you -I was feeling it wasn’t best so had disconnected the beosystem in the meantime. The one remote solution seems by far the neatest and easiest way to solve my problem. Then just to wire up the power link cables! It will keep me busy.
Millemissen
Flensborg, Denmark
@Stefan, Carolpa, Guy.....
I can’t test it - but doesn’t the BM6500 have an option 4?
This indicates that it has:
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Bang-Olufsen-Beomaster_6500-Service-Manual.pdf
In that case the BM6500 could be set to option 4 - which then means, that altist has to use the Link command before any command for the Beosystem 6500 (and that the BV would not react).
P.S. The right way to go IMO, would be to use the NL/ML Converter....makes everything much easier, once set up/configured.
Carolpa
ONLINE
Millemissen:
Correct
Millemissen:
not to my knowledge
Steve at Sounds Heavenly
The cable workshop, Leics, UK
There is a simpler option - connect the speakers to the TV and link the Beomaster to the 9 pin AV input of the TV with this cable to share the speakers:-
https://soundsheavenly.com/tv-input/138-2294-9-pin-av-cable-for-beovision-11-12-new-generation-avant-v1-and-beosystem-4-powerlink-input.html#/4-length-3m
No need for any kind of switch or converter.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Millemissen
Flensborg, Denmark
Steve at Sounds Heavenly:
Sure, Steve - however that does not solve the issue that altist has.
This is :’the problem is the pressing of TV controls on Beo 4 is picked up by the Beomaster as AUX.’.
Millemissen
Flensborg, Denmark
Carolpa:
Millemissen:
not to my knowledge
But according to that linked document it should have.
Would be nice if someone could try that out.
Page 1 of 2 (21 items) 1 2 Next > | RSS
