BeoMaster 4500, can’t adjust balance/loudness/treble
Answered (Verified) This post has 1 verified answer | 5 Replies | 0 Followers
marp
marp posted on Tue, Apr 27 2021 3:03 PM
Hi
I have an issue with my BM 4500. The balance display reads out “_ _ 0 8” and can’t be adjusted - same goes for the other sound options (though the current setting looks more normal). Only volume and start up volume can be adjusted accordingly.
As a result of this, there is no working left channel .. does anyone have a solution for this problem?
marp
Answered (Verified) marp replied on Sat, May 15 2021 7:49 AM
Verified by marp
SOLVED .. I put it in test mode and cleared the RAM, that’s all it took ..
pepps
Kent, UK
pepps replied on Tue, May 4 2021 10:59 PM
Can't you touch the 'reset' green light on the glass panel to set everything back to zero?
marp
Verified by marp
marp
marp
marp
marp replied on Sat, May 15 2021 7:50 AM
No, but I cleared the RAM and that fixed it.
Page 1 of 1 (6 items) | RSS
