Beolab 5 problem
Not Answered This post has 0 verified answers | 4 Replies | 1 Follower
beoinbuff
beoinbuff posted on Tue, Feb 5 2013 3:30 PM
So I thought I would see if some of the experts here could diagnose my problem so I will have somewhat of a clue to tell the service people.
I recently hooked my lab 5s up using the coax digital to a preamp that has a digital out.  I have had absolutely no problems with them previously using the line in.  Now, when playing through the digital connection, the right speaker makes a crackling noise that sounds like it's only coming from the top tweeter.  To further try and isolate the problem and make sure it wasn't a problem with the preamp, I connected them using digital coax directly to my sonos.  Same problem.
I then swapped cables and made the right speaker the initial speaker in the chain instead of the 2nd speaker to see if it is a problem with that particular connection (digital in). Same problem.  In my mind, this means that maybe there's a fault with the digital in connection on my right speaker? Or, a problem internally with the R speaker and its ability to accept a digital signal?  If so, what is the possible fix for this?
Thanks for any advice
stefan
200 miles from Struer
Seems you did all tests you can do. If analogue sound is ok, it`s not the speakers. If you swapped the cable and it`s again the right BL5, must be the electronics od your right BL5. I would just tell the service people what you wrote here. If they come to your house, let them bring a BL5 replacement case.
BL5 won`t be repaired, the electronics will just be completely replaced - at your home -  Eprom with settings of your right BL5 will also be set to the "new" electronics to match the left BL5. The "old" electronics will be sent to Struer.
I`m not an expert, but I had a similiar problem with my left BL5. The replacement costs were 250 Euros. The dealer didn`t charge me for the work...
Hope this helps and good luck
Stefan
beoinbuff
Thank you very much. This is what I suspected. The sticky part is that I live about 6 hrs from the closest B&O dealer, not including Canada. Hope they're willing to send a technician because I'm definitely not shipping these monstrosities.
stefan
I took my BL5 to my dealers service place, the electronics were already delivered from Struer. Work took just an hour, so I could reinstall my BL5 the same day in the evening.
Requirements: original packaging and at least a large french car (Renault Espace...
BTW: How old are your BL5? Warranty?...
Stefan
beoinbuff
They are about 6 yrs old. My dealer contacted B&O to see if there is a local service center, which he thinks there is.
Page 1 of 1 (5 items) | RSS
