Beosound 5 encore
Not Answered This post has 0 verified answers | 10 Replies | 1 Follower
Paul cheacker
Spain
Paul cheacker posted on Sat, Apr 17 2021 9:53 PM
Hi does anyone know what format an external hard drive needs to be to plug into the beosound 5 encore. My pc is a mac
Current b and o Products
beosound 5 encore, beolabs 6000, beogram 4500, playmaker mk1
Pat
Pat replied on Sat, Apr 17 2021 10:49 PM
DLNA
Pat
Pat replied on Sat, Apr 17 2021 10:50 PM
You can try Twonky Media on your mac or similar
Paul cheacker
Spain
No what I want to fo is attach a hard drive directly to the beosound. But ive formatted the drive and it does not show on the beosound 5 rncore
Aussie Michael
Melbourne, AU
Hi Paul,
Ill try and help as much as my memory allows from all that time ago when i had one.
Firstly, i remember having a WD network drive with Twonky, but i am sure that i also attached a HDD to one as well.
From memory you have to get the BS5Encore to find / recognise the drive
It’s been years, but i think you have to press > > GO and there you can choose one of the options there in the service menu
Try that and hope it works.
lawrencejmcook
Paul cheacker:
Hi does anyone know what format an external hard drive needs to be to plug into the beosound 5 encore. My pc is a mac Current b and o Products
Paul,
I use(d) a 256GB thumb drive for my BS5E. I think I formatted it as FAT32.
If you want to use a large capacity hard drive, try exFAT.
Hungedu
United States
FAT32 should be fine. I use my BeoSound5 Encore with a Mac as well, and that has always worked for me.
BeoLab 5, BeoVision 7-55 MK2, BeoSound 5 Encore, BeoSound 9000, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, BeoLab 7-6, BeoSound 8, BeoTime (analog clock), Beo 4 remote.
Paul cheacker
Spain
Ok i will try the fat32 cheers for the advice appreciate it
Paul cheacker
Spain
Hi I have tried Fat32 and msdos fat but drive will not show on the boesound 5 encore, any idea why not?
lawrencejmcook
Paul, a few thoughts:
- Does the external drive have its own power supply, or is it powered by the USB socket? Some external HDDs require more power than the BS5E’s USB socket can provide. This shouldn’t be a problem with an SSD.
- If it is a HDD, is it actually spinning?
- What is the total capacity of the drive?
- Have you installed only 1 partition on it? More than one partition may confuse the BS5E.
- Have you connected it via a USB hub? If so, try connecting it directly.
- How much music (GB) do you have on the drive? The larger the music library, the longer it takes the BS5E to load it.
Carolpa
1. Where did you connect the usb hhd? Front or back?
2. Roles is set to CD or N.Music?
Page 1 of 1 (11 items) | RSS
