BeoMaster 1900-2: strong volume difference on tuner vs phono input ?
Not Answered This post has 0 verified answers | 3 Replies | 1 Follower
KolfMAKER
The Netherlands
Silver Member
KolfMAKER posted on Wed, Apr 14 2021 2:49 PM
I have a BeoMaster 1900-2 and a BeoGram 1800 connected.
When I listen to the phono source on my BeoMaster 1900-2 at a comfortable volume, and then switch to radio; the sound is much louder. I would say the tuner is comfortable at about 5 volume increments less then a the phono channel. So switching from Phone back to radio more or less blasts my ears out!
The BeoGram 1800 does not have a RIAA pre amp, but the BeoMaster 1900-2 does. I also tried a different turn table (a Philips), but with the same effect.
So I am a bit confused what the cause is.
But foremost, I am interested to learn how I can get the volume levels closer to each other.
Any suggestion welcome.
sonavor
Texas, United States
sonavor replied on Fri, Apr 16 2021 12:27 AM
I have noticed that as well on all of the Beomaster receivers I own. A number of the receivers have preamp source input level trimmers to adjust phono and tape inputs but there are not any adjustments for FM radio sources. Perhaps the FM broadcast these days are at higher levels than when the Beomaster receivers were produced?  I don't know.  I usually end up adjusting the levels on the phono and tape/aux sources as high as possible and so those about the same.  Then I have to remember to lower the volume when switching to an FM source.
I don't have a solution for you but I can confirm that what you are hearing is typical.
-sonavor
Dillen
Copenhagen / Denmark
ONLINE
Dillen replied on Fri, Apr 16 2021 5:47 AM
Most FM stations use a lot of compression these days, giving them a "massive" sound.
They think it's modern and smart.
I get tired of listening to it.
Søren Mexico
Mexico City
Dillen:
Same here in Mexico, all stations trimmed for cell phone and earbuds listening
Page 1 of 1 (4 items) | RSS
