Quick BL Transmitter 1 Question
Not Answered This post has 0 verified answers | 4 Replies | 0 Followers
jabell
jabell posted on Thu, Apr 8 2021 9:25 PM
Hi folks,
There is a switch on the back of the Transmitter 1 that says "B&O input." You can either select "yes" or "no." Does anybody know if this is referring to whether or not you're using a B&O TV, or is it referring to the input of connected speakers?
I recently started using my Transmitter 1 again and forgot which selection is correct. For your reference, I am using a Samsung TV connected to a Transmitter 1 via optical, connected wirelessly to BL20s (via WiSA).
Thank you!
Jeffrey
Millemissen
Flensborg, Denmark
ONLINE
Quick reply:
B&O INPUT (YES – NO)
Input signal switch: YES is for connection of a
Bang & Olufsen system, and NO is for connection
of a non-Bang & Olufsen system.
 https://www.manualsdir.com/manuals/803384/bang-olufsen-beolab-transmitter-1-user-guide.html?page=4
jabell
jabell replied on Thu, Apr 8 2021 11:41 PM
When you say “connection of a Bang & Olufsen system,” are you referring to a connection of a B&O TV or a connection to B&O speakers?
Bill Briscoe
Chicago, IL USA
ONLINE
it's for the input (TV), not the output (speakers)
jabell
Got it, thank you! Smile
Page 1 of 1 (5 items) | RSS
