Beolab 17 buzzing noise
Not Answered This post has 0 verified answers | 5 Replies | 0 Followers
James1980
James1980 posted on Tue, Mar 30 2021 8:48 PM
Evening all, hoping someone can help!
I have a set of lab 17’s that I usually use via wisa, however last week my moment gave up and left them about as useful as ornaments. So, I thought I’d plug them in to the V1 I have set up and use them there instead. The dealer have me RJ45 cables, I’ve reset the speakers, daisy chained one to the other, and then one in to the V1 and set up the speakers via the menu. They work, however there is an audible hum, much louder than I’ve heard from other beolabs before. Unable to swap cables as I don’t have any others, have I missed something obvious? Or do these usually have a hum when wired? It’s noticeable at normal listening levels and very obvious during quiet scenes or in between tracks.
thanks in advance everyone.
james
Beovision 10, Beoplay V1, Beolab 17, Beolab 9, Beolab 4,  Beosound 2, Beosound Moment x 2,  Beoplay M3, Beogram 1700
CB
> You are Here <
CB replied on Wed, Mar 31 2021 8:52 PM
Check if they are Cat7 cable, or Cat6 SFTP.
lawrencejmcook
I’ve used my BL17s with a V1-40 with B&O RJ45 cables; there was no buzzing at all.
Instead of daisy-chaining the speakers, connect each one direct to the V1, setup once more and try again. This should help you tell if one of the cables is bad.
Also, do you get the noise with all V1 sources?
James1980
I tried to connect both directly at first and one speaker didn’t come on. I’ve lost the back panel to the V1 so can’t see what’s what, maybe I put it in the puc port?!
yes it’s consistent across all sources.
Millemissen
Flensborg, Denmark
ONLINE
James1980:
Not the biggest problem in the world...
James1980
Thank you, sir!
Page 1 of 1 (6 items) | RSS
