Beotime problem with display and navigation pad
Not Answered This post has 0 verified answers | 1 Reply | 0 Followers
Filip
Copenhagen, *Denmark
Filip posted on Mon, Mar 22 2021 3:55 PM
Hi - I recently bought a Beotime, advertised as faulty, so I kind of knew what I was getting myself into.
While visually beautiful, it has two problems:
1) Display 3 is completely dead, no lights, no numbers, no nothing.
2) The directional pad does not work 'to the right' which means it is impossible to access the menus, set the time etc.
I wonder if it is possible to repair it at all. Any ideas?
/Filip
leosgonewild
Helsinki, Finland
Silver Member
It’s fairly easy to get the displays off. You have to be careful if you want to take the internals out of the flute, that’s how I broke one.
The dead display might be a bad connection.
If you are real “lucky”, the ribbon cables are broken because somebody has been poking around where they shouldn’t.
Page 1 of 1 (2 items) | RSS
