Beomaster 3000-2 LOUD buzzing noise?
Not Answered This post has 0 verified answers | 2 Replies | 0 Followers
cnfs
cnfs posted on Mon, Mar 22 2021 8:46 AM
Hi everyone :)
I have this Beomaster 3000-2, I tried turning it on, but all that happens is that it produces this loud buzzing.
Here is a video of the problem:
https://youtu.be/_xqNFT_imoI
I am a novice when it comes to B&O, but happy to learn! Hope some of you can point me towards a solution!
Thanks in advance!
Best Regards, Christian
manfy
manfy replied on Wed, Mar 24 2021 8:21 AM
Hi Christian,
In your utube it looks like the sound is coming from the unit itself and it seems that the buzzing noise is increasing in the first 5-10 seconds.
Is this correct?
If so and provided there are no speakers connected yet, my first guess is magnetostriction. That means an aging transformer with less than perfect coatings on the core iron laminates and/or windings is causing the buzz. Degrading rubber bushings intended to avoid transmission of those vibrations to the chassis can be another cause of enhanced buzzing.
You'll have to open up the unit to pinpoint the actual source of that noise.
Anyway, you said "I tried turning it on, but all that happens is..." and this suggests that buzzing is all the unit does!?
We need more details and maybe a bit of history of that unit to be able to help.
rgds,
manfy
Dillen
Copenhagen / Denmark
Dillen replied on Wed, Mar 24 2021 1:42 PM
The transformer can also hum from an overload.
Isolate the transformer secondary and try again.
Still humming - replace the transformer.
No longer humming - check for shorted output stage(s) or bad filter capacitor.
Page 1 of 1 (3 items) | RSS
