Beovision 7-40 mk6 problem with the navigation
Not Answered This post has 0 verified answers | 2 Replies | 1 Follower
henrik_2000
henrik_2000 posted on Sat, Mar 20 2021 11:09 AM
Hi, I got a 2nd hand Beovision 7-40 mk6, but I have a problem with the navigation.
I would like to make a fresh start and delete all the old settings. But I can not navigate with the "arrows" only with the numbers on the remote. I have a Beo4, which is working fine with my Beovision 7-32.
It is like the whole set-up is fixed/locked, maybe like a tv in a hotel room, where you are not able to change anything.
I can navigate in some of the menues with numbers, but it is impossible to change anything.
Anyone experienced this problem?
Guy
Buckinghamshire
Guy replied on Sat, Mar 20 2021 1:14 PM
Hi and welcome to Beoworld!
I assume that you are using a Beo4 that does not have the little joystick in the middle (in place of the GO button).  This is probably causing the problems.
If you have a look at the user guide you will see several footnotes about using a Beo4 without the joystick 'navigation button'.  Look here for the manual: https://bangolufsenassistentgohe.blob.core.windows.net/manuals/TELEVISIONS/BEOVISION_7-40_55/beovision_7_40_mkvi_7_55_mkii_getting_started_english.pdf
EDIT: And in the TV's OPTIONS menu you should then be able to set up the TV to use a Beo4 without navigation button - see footnote at the bottom of page 9.  This should make life easier!
henrik_2000
Yes you are absolutely right!
I had to change the remote control in the menu to be operated without a navigation button.
Thanks a lot - I'm very happy
Page 1 of 1 (3 items) | RSS
