Audirvana with Besound Core
Not Answered This post has 0 verified answers | 20 Replies | 2 Followers
jgraefe
jgraefe posted on Tue, Mar 2 2021 1:30 PM
does anybody use this combination? I can play music on my beoplay a6, but not on my core.
I'm looking for a solution to play my flac music files with my core. I know the B&O App, but this app is really bad for a big music collection.
So i tried audirvana, because they have a nice app for ipad and iphone - i think...
Do you have any ideas?
BS9000 + BS Core + Beosystem 3 + BL8000 + BL4 + BL2 + BL7-1 // BeoVision 7 32“ + BL8000 // Beoplay M5 // Beoplay S3 // 2x BL3500 // 2x BeoPlay A6 + 2x Essence Remote // 2x BeoSound 8 // Playmaker + BL6000
mbolo01
Louannec - France
jgraefe:
Hi - How do you play your music to your A6? You should be able to do the same with the Core (I’m assuming you have speakers connected to the Core)
jgraefe
mbolo01:
Hi - How do you play your music to your A6? You should be able to do the same with the Core (I’m assuming you have speakers connected to the Core) BS Moment, BS Core, BG 4002, BC 4500, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, P6 (tks Botty), H5, TR1
I Play to my A6 the Same way, But ist wont work With the Core. My Core is connected to aux in of my bs9000 and works as brain with my converter...
jgraefe
mbolo01:
Audirvana is Not starting playing music.
mbolo01
Louannec - France
and what is the path between Audirvana and the Core?
jgraefe
mbolo01:
Audirvana Runs on a Mac Mini Server Core2Duo (connected via LAN) and the Core is also connected via LAN. The A6 is connected via WLAN.
Carolpa
jgraefe:
and they all are on the same network?
mbolo01
Louannec - France
jgraefe:
Are you using Audirvana as a DLNA server?
jgraefe
Yes all the same Network. the B&O App is working with twonky, but has a terrible Interface [:\'(]
The Audirvana App is showing the Core, so i think its dlna?
Carolpa
jgraefe:
That depends on the DLNA server used.
Carolpa
jgraefe:
first stop Audirvana. Do a reboot on your Core (mains out - wait a minute -mains in).
Restart Audirvana. Choose Core as output device in Audirvana. Start to play music........... Does Audirvana start to play now?
Carolpa
mbolo01:
he using it as a music streamer.
Audirvana is no dlna server
mbolo01
Louannec - France
jgraefe:
I don't know the Audirvana app but it seems to only be a remote if it is the IOS App you are referring to, which means that either Airplay is used from the Mac Mini, or the Audirvana App acts as a DLNA controller for the Audirvana server running on the mac mini and the Core DLNA renderer service.
Have you tried adding the Audirvana DLNA server in the B&O App to see if (1) it sees the DLNA server and (2) if you get a sound this way?
How to (case needed): In the B&O App go to settings (the body shape at the top right), Music, DLNA, + (top right) should list the available DLNA server(s) on your LAN
jgraefe
Ist works After restarting everything.
Audirvana does not have a dlna Server. For this i tried twonky / kodi ... and many more in combination with the B&O App. But i am Looking for an App with better handling. I want to create Playlists, i want to search for Songs etc.
Carolpa
jgraefe:
but stop/release the stream (in Audirvana) after you finally want to stop to listen otherwise the Core can be become stuck.
if you do so, it will work just fine.
Page 1 of 2 (21 items) 1 2 Next > | RSS
