how to connect beosound 1 2nd gen to a logitech bluetooth
Not Answered This post has 0 verified answers | 2 Replies | 0 Followers
dj1979
dj1979 posted on Tue, Feb 23 2021 3:30 AM
hi all,
I have a bit of an issue here. I have a tv which doesnt have bluetooth output. So i brought a optic sound out supported bluetooth from logitech.
Now i have to pair this device with beosound1, how is it possible?
Stan
Chicago-area USA
Stan replied on Tue, Feb 23 2021 7:20 PM
If the BS1 supports Google Voice Assistant, you say "Hey Google, I want to pair bluetooth", and it will open for pairing.
If it doesn't, then I assume it's like my BS2 (gen1) where you go into the B&O app and select product settings -> configure -> bluetooth
I can't help you on the logitech side.
dj1979
dj1979 replied on Thu, Feb 25 2021 8:41 PM
Thanks a lot. It worked. I had to remove the beosound registered to mobile app too. Otherwise it was trying to connect to this. Then I tried the voice command, and it said error connecting and asked me to try again. Then I saw it's blue light on bluetooth and it's good
Page 1 of 1 (3 items) | RSS
