Beovision 11 3D Glasses
Answered (Verified) This post has 1 verified answer | 11 Replies | 2 Followers
Tedwood
Tedwood posted on Mon, Jan 28 2013 6:55 PM
Very pleased with 3D performance on my new TV.
I know that the glasses work on the shutter principle.  Does Anyone know if another make of same technology glasses will work with the Beovision 11?
Spoken
Answered (Verified) Spoken replied on Tue, Jan 29 2013 1:00 PM
Verified by symmes
The xpand x103 will work. It's the same like the original b&o but much cheaper!
Spoken
Verified by symmes
Tedwood
Great, thanks for your advice.
BeoSin
Hong Kong
BeoSin replied on Tue, Jan 29 2013 4:57 PM
I got the BV11 46 to replace my link room BV7 32 MK IV. Didn't get the 3D glass as I thought 3D wouldn't look very good on a 46" screen. Are you on 55" ?
Tedwood
I bought the 46 on the motorised stand.  3D v good so far.  Quality of sports coverage is a little mixed depending on the camera height.  May be it's the weight of the cameras, but some of the positions are lower than those of the 2D normally used, which gives a manager's eye view!! Overall pleased.
CheapB
CheapB replied on Tue, Jan 29 2013 5:45 PM
There are (at least) 2 types of active shutter glasses - IR and RF. I believe BV11 ueses IR, but it would be great if someone could confirm. The cheapest "guest" glasses for IR 3D are the Playstation glasses http://www.amazon.com/PlayStation-3-3D-Glasses/dp/B00562O8U0/ref=sr_1_1?ie=UTF8&qid=1359480839&sr=8-1&keywords=playstation+3+glasses
They can often be had for $20.
Spoken
Spoken replied on Tue, Jan 29 2013 7:18 PM
The Beovision has IR 3D. But that doesn't mean that every IR Glasses can be used. B&O has implemented the xpand Technology, so the Glasses work 100%. If tried Samsung IR Glasses before but that doesn't work.
The native 3D Mode from a Bluray Is impressive on a 11-46.
Gennaro
Bronx, NY
Hi guys,
I need some advice and help.. I just pick up a BV 11-55 Mk2 and was wondering what alternative 3D glasses can I buy that would work with the tv. Since it's hard to find the B&O ones....
Beovision 11-55, BeoPlay V1 40, Beosound 9000, Beolab 8000's and 3 Beocom 5's... Smile
Millemissen
Flensborg, Denmark
Maybe these will do the job?
https://www.amazon.com/Xpand-Glasses-single-Discontinued-Manufacturer/dp/B00462RMS6
Gennaro
Bronx, NY
You think they'll work?
Daniel
Svinarp, Sweden
Daniel replied on Mon, Sep 26 2016 7:24 PM
Sorry, but I don't think they will work. I tried many others glasses for my Avant 55, but I ended up buying two used (B&O original) pairs from Mr Anders_son. All others I had to send back. Search this forum for 3D glasses, I wrote about it here.
Is it not possible to buy new ones from B&O?
Gennaro
Bronx, NY
Just don't feel like paying too much for the glasses... lol
Since they have a ton on Amazon for less...
Page 1 of 1 (12 items) | RSS
