[SOLVED] Netradio on Beovision Avant 55
Answered (Verified) This post has 1 verified answer | 7 Replies | 1 Follower
Giovanni
San Francisco Bay Area
Giovanni posted on Thu, Jan 21 2021 5:23 AM
Hi
does anybody use Netradio on a Beovision Avant? Whenever I try to use it, it only shows the Bang & Olufsen test streams, and those don't even play. I get Connection Error.
Anybody can help with this?
Giovanni
Giovanni
Verified by Giovanni
Ok so I solved the issue, thanks to B&O Customer service.
On the remote press:
  1. Menu
  2. Settings
  3. Red then GO (customer service menu)
  4. Settings
  5. Reset to default
  6. Reset N.Radio to default - Press GO
  7. Please disconnect and reconnect the power of the unit and the database should start downloading.
If the above-mentioned steps have not updated the Net radio stations, kindly try the steps below:
In the network settings:
  1. change the configuration to manual
  2. now change the DNS IP to 8.8.8.8
Millemissen
Flensborg, Denmark
ONLINE
I use it every day since it was added through an update a long time ago....without problems.
How are your ‘power saving settings’?
Giovanni
I think I have the defaults on power saver.
Network Power Saver settings (wlan, wake on lan...) are ON
auto standby 4 hrs
sound/picture economy mode is off
beolion
beolion replied on Thu, Jan 21 2021 11:36 PM
I also have the default on my Avant 55 mk1 and Net radio is working fine.
I just turned on my fav Nova Sydney FM.
Giovanni
Giovanni replied on Fri, Jan 22 2021 12:42 AM
That's good news!
did you do anything special to your network setup or sign in to any Bang & Olufsen online products?
G.
Giovanni
Giovanni replied on Tue, Apr 13 2021 10:19 PM
Just an update here. My Avant 55 is still not able to access Netradio. The interesting thing is that by looking at the network traffic it's trying to access a website pnetradio.bang-olufsen.com which does not have a valid DNS entry. So, it cannot download the list of radio stations and hence cannot access the product.
I flagged this to B&O tech service and they are looking into it.
Giovanni
  1. Menu
  2. Settings
  4. Settings
  5. Reset to default
Aussie Michael
Melbourne, AU
Thanks Giovanni
Page 1 of 1 (8 items) | RSS
