Hi everyone,
i have an a question. In a 5.1 set up with BL17 as front, BL11 sub, and BL6002 as surround, the correct setting of the center channel on Eclipse is: Eclipse-C center front active and Eclipse-L and Eclipse_R disactive, or C-L-R set all center front active ?
Many thanks
Eclipse 65V1-32Beosound M5Essence MK2BLI
BV Eclipse 55 Brass - BL 18 Brass - BL 19 Brass - BL17 Black - BL 3 White - BS Moment - BS 2 Brass - BV Horizon 48 - BS3000 - BS 3200 - BS Essence MK2 - BL 4000 - V1 40 Black - V1 40 White - BLC NL/ML - H6 - H4 - E8 Motion - A8 Earphone - Beolit 12 - Beolit 15 - Beoplay A1 Green - Beoplay A3 White
Seanie_230:It is but it’s actually 5.1 but says 7 because you have three channels doing centre Eclipse 65 V1-32 Beosound M5 Essence MK2 BLI
Fansastic:I stand corrected: the sound info on Eclipse will say 7.1 output indeed. But it is not a 7.1 setup. The true image processor is sending the center channel to the three speakers in the Eclipse BV Eclipse 55 Brass - BL 18 Brass - BL 19 Brass - BL17 Black - BL 3 White - BS Moment - BS 2 Brass - BV Horizon 48 - BS3000 - BS 3200 - BS Essence MK2 - BL 4000 - V1 40 Black - V1 40 White - BLC NL/ML - H6 - H4 - E8 Motion - A8 Earphone - Beolit 12 - Beolit 15 - Beoplay A1 Green - Beoplay A3 White
Seanie_230:I have all of mine set as centre and have fronts also. There is a post from Geoff about how to set this up. Eclipse 65 V1-32 Beosound M5 Essence MK2 BLI
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Watch this:
https://youtu.be/svIUxzKzI8E
Start at 14.30......or watch from the start ;-)
Many thanks ,but I am a bit confused.
So what seems to be the best solution to set the central channel ?
New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0
mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
So how did you set up your center channel ?
