Hi..
i just Got a playmaker to my livingroom , and like it
now i want one more in my bed room ..
i Got a beovision 10 and a set of 3 speakers ..
how do i do ? Can i connect the playmaker to the tv ? (The tv has powerlink to the speakers )
Have a look at Millemissen's 31 Jan post in this thread: https://forum.beoworld.org/forums/t/29504.aspx
Relevant part as follows:
Millemissen: Personally I’d go for a Playmaker (output of the PL set to fixed line-out) connected to a scart adapter via R/L - that is, if you are into AirPlaying. Set the BV to option 2 (if ML built-in). Sending the AV command before the Source selected for the scart, then will result in the tv starting up with a muted screen. MM
And if you need further help with the Playmaker setup then there is lots of information in the publication 'Installation Guide for installation and setup of Playmaker Version 1.0' Unfortunately I can't find a copy on the site but an internet search should find it. Otherwise, let me know and I'll PM you a copy.
A copy of the Playmaker Setup Manual version 1 can be found HERE
Regards Keith....
Keith Saunders: A copy of the Playmaker Setup Manual version 1 can be found HERE
Thanks Keith - I do struggle with those User Manual menu/folder structures. In this case I didn't realise that the Playmaker was a 'Beoplay' device. Any chance that a 'search' function could be added to 'User and Service Manuals' (like the one for 'Products')?
Guy: In this case I didn't realise that the Playmaker was a 'Beoplay' device.
Its not, so I have moved it and I have updated the links in this thread.. Thanks for pointing it out..
Keith Saunders:Its not, so I have moved it and I have updated the links in this thread.. Thanks for pointing it out.. Regards Keith....
My copy too is complete as single 1Mb pdf, let me know if you need it. (It's also quite good quality, not a scan).
Guy:My copy too is complete as single 1Mb pdf, let me know if you need it. (It's also quite good quality, not a scan).
I have PMed you, but I have also stuck it on this shared link for the next hour or so: https://www.myqnapcloud.com/smartshare/6he033i7o61n82628w5zab22_6QJbsK3
EDIT: Share now deleted as file available on site - see below.
Thank you Guy, I can confirm it is now on the web site in place of the incomplete copy.
No problem Keith, happy to help!
I've switched off my share now.
Keith Saunders:Thank you Guy, I can confirm it is now on the web site in place of the incomplete copy. Regards Keith....
lawrencejmcook:Hi Keith, Per my post from last August: “I have two pdfs for the Beoplay V1 wall brackets: - One for Type numbers 4726 / 4737 - One for Type numbers 4752 / 4753 I’m happy to submit them for inclusion in the Beoworld User Guide library if you tell me where to send them. They’re no longer on the B&O zendesk site, as far as I can see.” Lawrence
Lawrence
If you email them to me I will add them.. Keith@beoworld.org
