Beosound 5 Encore power supply missing
Not Answered This post has 0 verified answers | 8 Replies | 1 Follower
cc31
cc31 posted on Thu, Jan 14 2021 7:13 AM
I have lost the power supply to my Beosound 5 Encore and am wondering what to do.
Is there anything I can use as a replacement or can anyone recommend where to get a new one?
Thank you very much!
BenSA
Durban, South Africa
BenSA replied on Thu, Jan 14 2021 12:00 PM
Sadly B&O discontinued the power supply years ago. Extremely difficult to find as its specifically made for the Beosound 5. I suggest you try and find the one you had.
frog
Camberley UK
frog replied on Thu, Jan 14 2021 7:52 PM
Way back in 2014, the PSU was already discontinued nd there is no stock anywhere!
You may be able to put one together with two PSUs - one 30v/0.7A and one 7v/0.5A. The 7v line is used for standby.
Not sure about the connector to the Encore though - I haven't seen it!
Keith Saunders
Hampshire, United Kingdom
frog:
May be more difficult than you think. I am sure you can find suitable power supplies for each of the voltage requirements, but the issue will be controlling the off/on of the supply. Note the PS_ON signal on pin 4
Regards Keith....
frog
Camberley UK
frog replied on Fri, Jan 15 2021 12:51 AM
It’s a good question. Would be useful if someone who actually had one put a meter on that pin to see what voltages it ran at. I hope it isn’t a ttl voltage otherwise it could be a data line.
cc31
cc31 replied on Fri, Jan 15 2021 3:09 AM
Thank you for your help
If I were to use the two PSUs together, you pointed out that the PS_ON signal on pin 4 would be an issue.
Do you have solutions or suggestions for this problem?
Keith Saunders
frog:
It is a voltage. 6.3 volts is the on state..
Regards Keith....
frog
Camberley UK
frog replied on Sat, Jan 16 2021 4:27 PM
interesting. So joining pin 3 & 4 may make it work.
Beobuddy
Utrecht, The Netherlands
Eh, why?
The PS-on comes from the Encore which triggers the 30V PSU. No data on that line. None of the PSU’s used in B&O products carriers data on the PS-ON. It’s just a trigger/state for switching on/off.
Page 1 of 1 (9 items) | RSS
