Today I have a Beosound Core, connected to Beolab 11 subwoofer and then on to two Beolab 4000 (with powerlink).
After I added BL11, the sound got a real boost - used only for music.
However, I'm wondering what a step up in speakers could be?
They must be able to be wall mounted.
How do you think Beolab 3 would play, without the subwoofer and with the subwoofer compared to my current system?
Is it more important there that the speaker's treble is aimed at the listener than today?
Or if I sell both BL11 and 4000, to buy Beolab 17 (only used now for about 2000 euros).
On paper, they seem to play about as low in frequency.
Any tips or something?
Beolab 17 all day, every day!
I’ve owned both, and it’s night and day. Lab 17 all the way.
Beovision 10, Beoplay V1, Beolab 17, Beolab 9, Beolab 4, Beosound 2, Beosound Moment x 2, Beoplay M3, Beogram 1700
Thanks. Would that “little” speaker BL17 be able to produce the same amount of bass and volume? About same frequencies?
Way more than the 4000, and you potentially wouldn’t need the 11 either. 17’s really are incredible for their size, my other ‘listening speakers’ are lab 9’s and while there is a difference in bass extension, it’s not anywhere as big as you might envisage.
Sounds almost to good to be true, because the BL17 is that small speaker!
No ideas about changing to BeoLab 3? I guess they without subwoofer can be little flat? And with BL11, it’s more money than buying the BL17.
Feedan:Sounds almost to good to be true, because the BL17 is that small speaker! No ideas about changing to BeoLab 3? I guess they without subwoofer can be little flat? And with BL11, it’s more money than buying the BL17.
BV Eclipse 55 Brass - BL 18 Brass - BL 19 Brass - BL17 Black - BL 3 White - BS Moment - BS 2 Brass - BV Horizon 48 - BS3000 - BS 3200 - BS Essence MK2 - BL 4000 - V1 40 Black - V1 40 White - BLC NL/ML - H6 - H4 - E8 Motion - A8 Earphone - Beolit 12 - Beolit 15 - Beoplay A1 Green - Beoplay A3 White
Just to be clear. mid I chose the BeoLab 3 speakers, but won’t run them with the BL11 or other sub, will the sound be that flat without bass?
I think BL17 is worth its money now as used ones. No new ones are produced any more. But the prices as new ones felt a bit to expensive for that kind of speaker. I’ve read people says they are better than the Lab 18..
You will find no shortage of forum friends touting BL17 as amazing, myself included. For their size, they’re unusually good. Yes, BL18 is prettier but the bass is not there. The BL18 may be better for off-axis listening due to ALT and may have a slightly more crisp treble but that’s not even clear. BL17 is amazing.
Currently: BeoLab 17, BeoLab 18, BeoSound Core, BeoPlay S8 Connection Hub, Essence Remote
Previously: BeoSound 1 non-GVA
