i'm looking for a BS4 with DAB+. If anyone will sell it, pls contact me :-) (alternatively a BC2 with DAB+ )
There are a lot of BS4 or BC2 in the net, but most of them or all without DAB+. Can anyone confirm, that a BS4 which is marked with Acc.: DMB is equipped with DAB+????? Normaly all BS 4 and BC2 with DAB are marked with Acc.: DAB
In my opinion the only solution was to ugrade a BS4 or BC2 with a module to recieve DAB+. Unforunately this module is not longer in the B&O stock. Or is it possible to update a BS4 or BC2 wich is equipped with a (old) DAB module via flashtool to recieve DAB+????
Kind regards!
Michael
This one is a bit pricey, but the label on the box says DAB+
https://www.ebay.co.uk/itm/B-O-BeoSound-4-Music-System-Radio-with-CD-Player-and-SD-card-on-a-Floor-stand/303352930577?hash=item46a13e6111:g:16AAAOSwnhNdxB9M
EDIT; And there's some useful info here: https://forum.beoworld.org/forums/t/6393.aspx
thx Guy!!!!
wow...1850 pounds are really a lot :-) ok, the BS4 is brandnew, but thats too mutch.
But i asked the seller for a photo from the label. hope to see if the BS4 is marked as DAB or DMB :-)
Hello Michael,
I can confirm that my BS4 with DAB+ is marked Acc: DMB (not for sale). One unit is for sale on the Norwegian Ebay-equivalent today, at a decent price. Most likely an upgraded version. It reads Acc: DAB, but seems to receive NRK which is only distributed by DAB+.
https://www.finn.no/bap/forsale/ad.html?finnkode=204026433
Sverre
Sorry, double post
Thanks a lot!
I found a BS4 with DMB=DAB+ :-) The price was really small, including a pair of BL4.
I received the parcel with the new BS4. And YES it is equipped with DAB+
If you are looking for a DAB+ Versoin, it is marked with Acc.: DMB
I think that they are very rare...
Kind reagrds!
