Hi
I just bought a used Beovision Avant 55 2014 model from a B&O dealer. The software is the latest, and hdmi port 1 supports hdmi 2.0 and hdcp 2.1. The screen should therefore handle 4K 60hz SDR, but my Avant only supports up to 30hz. When I try 60hz SDR, half the screen turns green. B&O support in Denmark thinks there is something wrong (defective internal cable that is limiting the input from the HDMI) The dealer don´t agree and thinks there's nothing wrong... So I'm confused. Anyone in here who has an Avant55 from 2014 that uses Apple TV 4K 60hz SDR that works? Best regards Robert
Hi Michel
All I need is someone to verify that Beovision Avant MKI should work with Apple TV 4K 60hz SDR - and you helped me with that. Thank you very much! The firmware is the latest - that is verified by B&O support in Denmark.
Best Regards Robert
Robert_A:Hi I just bought a used Beovision Avant 55 2014 model from a B&O dealer. The software is the latest, and hdmi port 1 supports hdmi 2.0 and hdcp 2.1. The screen should therefore handle 4K 60hz SDR, but my Avant only supports up to 30hz. When I try 60hz SDR, half the screen turns green. B&O support in Denmark thinks there is something wrong (defective internal cable that is limiting the input from the HDMI) The dealer don´t agree and thinks there's nothing wrong... So I'm confused. Anyone in here who has an Avant55 from 2014 that uses Apple TV 4K 60hz SDR that works? Best regards Robert
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Hi Michael!
Thank you for your reply! The cable I use is Belkin UltraHD 4K Hdmi. I have also tried with another cable with the same result. The chroma is on 4:4:4 when the output is 4K 30hz SDR and it works. When I try 60hz, it dont work with chroma 4:4:4 or 4:2:0
Why the dealer not listen to B&O denmark that have the expertise on this?
if they say it some internal cable wrong, let the dealer repair it as denmark recommand. It should be and easy fix if denmark support the deale how to repair.
andybandy:Why the dealer not listen to B&O denmark that have the expertise on this? if they say it some internal cable wrong, let the dealer repair it as denmark recommand. It should be and easy fix if denmark support the deale how to repair.
Robert_A:Hi Michel All I need is someone to verify that Beovision Avant MKI should work with Apple TV 4K 60hz SDR - and you helped me with that. Thank you very much! The firmware is the latest - that is verified by B&O support in Denmark. Best Regards Robert
I will second that statement. The Apple TV 4K 60hz SDR definitely works seamlessly with the Avant 55" Mk1
