I have today a pair of BL50 connected to an Eclipse 65 with powerlink.
When listening to Deezer/DLNA Music, will the sound quality be better if I buy a Beosound Core and feed the speakers directly with Optical cable between the speakers and the Core?
Best regards
Sweden
Beovision Eclipse 65 with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5, Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K. Beoremote HALO (new), 3xBeoplay Charging pad
New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0
mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Compararing two experiences will always be very different, mostly due to the small differences in the sound pressure level and also the differences in the processing in the BV (you’d have to be very carefull there). Also our memory of listening is very short and the danger of prefering, what is ‘supposed to sound better’ is big.
So, better....hmmmm - I am not sure, what that means. But the sound might be different!
Unless you are someone who sits down a lot and listen a lot to music, I’d go for the comfort of a connection through the BV.
However - as always with music/sound - try out things in your own room and pick what you like best.
Hi guys,
My thoughts was IF Beosound Core with optical out directly to BL50 is a better solution regarding adioquality vs Soundcenter in the Eclipse with powerlink.
There are less D/A coversions when using a digital source directly to BL 50.
But maybe there are so little difference so it is an unnessery investment in the Core.
IF someone have tried both setup:s as described above then please give your opinion.
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
I quite liked the Bluesound interface when I tried the Node 2i.
https://forum.beoworld.org/forums/p/42885/311656.aspx#311656
Currently: BeoLab 17, BeoLab 18, BeoSound Core, BeoPlay S8 Connection Hub, Essence Remote
Previously: BeoSound 1 non-GVA
Curly:I quite liked the Bluesound interface when I tried the Node 2i. https://forum.beoworld.org/forums/p/42885/311656.aspx#311656 Currently: BeoLab 17, BeoLab 18, BeoSound Core, BeoPlay S8 Connection Hub, Essence Remote Previously: BeoSound 1 non-GVA
When discussing the Node 2i, some forum peeps suggested it’s not really that good a streamer and not a reasonable partner to BL50. They suggested Lumin or Auralic. Those are about 5x the price of the Node 2i... maybe it’s worth it? Maybe not?
Curly:When discussing the Node 2i, some forum peeps suggested it’s not really that good a streamer and not a reasonable partner to BL50. They suggested Lumin or Auralic. Those are about 5x the price of the Node 2i... maybe it’s worth it? Maybe not? Currently: BeoLab 17, BeoLab 18, BeoSound Core, BeoPlay S8 Connection Hub, Essence Remote Previously: BeoSound 1 non-GVA
I get it. Just note that if you use the Toslink output, the Node 2i won’t fully render MQA. You’ll be limited to a max of 96/24. To get 192/24, you’ll have to use the RCA outputs (which will introduce an additional conversion step relative to keeping the source digital with Toslink).
Let us know what you think! I really liked the Node 2i. Bluesound is very slick.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
