Sound quality question: Eclipse/powerlink with BL50 vs BS Core/optical out to BL50?
Not Answered This post has 0 verified answers | 15 Replies | 0 Followers
Sweden
Martin posted on Wed, Jan 6 2021 9:01 AM
I have today a pair of BL50 connected to an Eclipse 65 with powerlink.
When listening to Deezer/DLNA Music, will the sound quality be better if I buy a Beosound Core and feed the speakers directly with Optical cable between the speakers and the Core?
Best regards
Sweden
Beovision Eclipse 65 with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5, Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K. Beoremote HALO (new), 3xBeoplay Charging pad, Beoplay M5 (new)
Mikipidia
ONLINE
Better how? Better to listen to or better measurably?
New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0
mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Millemissen
Flensborg, Denmark
Compararing two experiences will always be very different, mostly due to the small differences in the sound pressure level and also the differences in the processing in the BV (you’d have to be very carefull there).
Also our memory of listening is very short and the danger of prefering, what is ‘supposed to sound better’ is big.
So, better....hmmmm - I am not sure, what that means. But the sound might be different!
Unless you are someone who sits down a lot and listen a lot to music, I’d go for the comfort of a connection through the BV.
However - as always with music/sound - try out things in your own room and pick what you like best.
Sweden
Hi guys,
My thoughts was IF Beosound Core with optical out directly to BL50 is a better solution regarding adioquality vs Soundcenter in the Eclipse with powerlink.
There are less D/A coversions when using a digital source directly to BL 50.
But maybe there are so little difference so it is an unnessery investment in the Core.
IF someone have tried both setup:s as described above then please give your opinion.
Best regards
Esax
Esax replied on Thu, Jan 7 2021 10:00 AM
Tidal sounds better streamed from iPhone to airport express with optical. Than tidal app on apple tv 4k. More clarity and better image. Even the bass in tighter.
Orderd a bluesound node 2i. Testing it this weekend.
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
Esax
Esax replied on Fri, Jan 8 2021 4:43 PM
First impression with bluesound node 2i. The phantom center is more pronounced. Wider sound image. And last but not least even clearer sounds throughout the register. The bass is clearly tighter, less boomy.
Curly
FL, USA
Curly replied on Fri, Jan 8 2021 4:49 PM
I quite liked the Bluesound interface when I tried the Node 2i.
https://forum.beoworld.org/forums/p/42885/311656.aspx#311656
Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Essence Remote
Previously: BeoSound 1 non-GVA
Esax
Esax replied on Fri, Jan 8 2021 5:09 PM
Curly:
Currently: BeoLab 17, BeoLab 18, BeoSound Core, BeoPlay S8 Connection Hub, Essence Remote
And you can turn of the light on the streamer. I wish b&o would listend to me when I told them I would like to turn of the light on the beolab 50.
Esax
Esax replied on Fri, Jan 8 2021 5:22 PM
When playing keith don’t go. Every gitarr string note is like a bullwhip in your face.
Curly
FL, USA
Curly replied on Fri, Jan 8 2021 6:03 PM
When discussing the Node 2i, some forum peeps suggested it’s not really that good a streamer and not a reasonable partner to BL50. They suggested Lumin or Auralic. Those are about 5x the price of the Node 2i... maybe it’s worth it? Maybe not?
Esax
Esax replied on Mon, Jan 11 2021 9:37 PM
Curly:
Non of those support tidal connect. And that’s wath I’m after.
Curly
FL, USA
Curly replied on Tue, Jan 12 2021 2:16 PM
I get it. Just note that if you use the Toslink output, the Node 2i won’t fully render MQA. You’ll be limited to a max of 96/24. To get 192/24, you’ll have to use the RCA outputs (which will introduce an additional conversion step relative to keeping the source digital with Toslink).
Let us know what you think! I really liked the Node 2i. Bluesound is very slick.
Michael
Sweden
I have BL50 and a new eclipse Gen 2, and a Beosound core but have yet to connect the core to the 50s.
I also wonder if it would make sense to use it instead of the eclipse in its many different ways of playing back music and sounds of all kinds.
Esax
Esax replied on Tue, Jan 12 2021 8:52 PM
Apple music via apple tv or airport, spotify via apple tv or airport, youtube music via apple tv or tidal via airport sounds good. Really good, not to much differens. But tidal sounds best on balance. Yeah it’s good and almost everybody is impressed.
But I know it could be better. Just something is missing.
Then I put on tidal via analog rca trough the bluesound node 2i. Don’t know if digital is better, don’t have the cabels for it yet.
It just put a smile on my face every time. And it’s not often it happens.
It is so much more details, and still so much less muddy noise you don’t want. And the punch in all the spectrum, wow. I’ll never go back!
Michael
Sweden
Regarding the sound quality.
I have some serious issues with the sound on my 50s. In wide mode they sometimes work fully - sometimes the bass however is sooo flat it’s silly! I can’t say what triggers it. Narrow mode is usually fine and has much more sound overall which I found very contradictory to what is the point.
The eq feature is also totally disabled for some reason. I’ve reset them and done calibrations with the mic I had to pay extra for (even though it’s clearly stated on several occasions in the manual that it is included)...
Getting a bit annoyed but hopefully it’s just bad firmware and will be fixed.
Page 1 of 2 (16 items) 1 2 Next > | RSS
