Masterlink Gateway and Beolink Gateway integration Home Assistant
Not Answered This post has 0 verified answers | 82 Replies | 2 Followers
Giovanni
San Francisco Bay Area
Giovanni posted on Tue, Jan 5 2021 4:36 PM
Hi there
Just to let you know that I created an integration between Masterlink Gateway and Beolink Gateway with Home Assistant with some really cool functionality to tap directly into the Masterlink bus and enable all kinds of fun integrations like controlling your digital streaming from your old school Beolink devices.
https://github.com/giachello/mlgw
Abakus2007
Hi Giovanni,
Thank You for sharing Your knowledge and skills this way, much appreciated.
I have one question if I may ask. I have s blgw where the setup if somewhat different from the mlgw, zones etc.
Do I need to make  many changes in the configuration, have added my sources etc in the .yaml file with sources and
devices like beomaster 5 and beolab 3500 and their MLN.
I have my devices in the control panel but not working and I get an error log when starting it up.
Thanks in advance
Baaz
Giovanni
Hi Baaz
can you send me your configuration, and also the cut and paste of your homeassistant logs? There are other users with BLGW and it works for them.
Also, if possible, could you please send me the file http://ADDRESS_OF_BLGW/mlgwpservices.json
Giovanni
Abakus2007
Giovanni,
thank You for taking Your time. I've gone back to a very simple installation to narrow down things. Only a Beomaster 5 installed  and two buttons Radio and CD. Also I'm not using the manual config but the automatic. Thing is Beomaster 5 pops up in the control panel but without sources and when I try to start i get the enclosed error code also enclosing mlgwpservices.
Baaz
Abakus2007
and the error code...
Giovanni
Excellent. This is a known bug and I am fixing it this weekend.
Abakus2007
Giovanni take Your time, when googling for answers I find You are equally busy helping people on the home assistant forum.
Have a nice Saturday evening
Baaz
Giovanni
Hi Baaz
I made the changes that should support your use case. Please install the latest code and let me know how it works for you.
Giovanni
Abakus2007
Hi Giovanni,
some progress, I can start the Beomaster 5, it puts on the CD, and stop once then nothing happens. No error log either.
Still no sources nor does any of the functions work pause or volume control.
If I manual include mlgw-script in the configuration I get an error log, if this could be to any help.
Mikael
Abakus2007
and the yaml
Giovanni
Hi Abakus2007
can you please add this to your configuration.yaml:
logger:
  default: warning
  logs:
    custom_components.mlgw: debug
then, do the automatic setup.
And send me the error log.
The two problems you described (not able to control and manual config failing) are independent from one another, but both seem fixable.
Giovanni
Abakus2007
Giovannu,
here we go, made 2 versions; 1st with added mlgw config in configuration.yaml 2nd with autoconfig only Your logger:
Baaz
Abakus2007
Abakus2007
Sorry Giovanni,
pls disregard my files, I've been playing with the blgw and added things, I'll strip it and get back with Beomaster 5 only and cd/radio sources.
Baaz
Abakus2007
Sorry Giovanni,
I've changed the blgw since last time, here is an errorautoconfig with only Beomaster 5 and cd/radio
Baaz
Abakus2007
and the 2nd file
Page 3 of 6 (83 items) < Previous 1 2 3 4 5 Next > ... Last » | RSS
