Penta midrange gaskets
This post has 1 Reply | 0 Followers
Kiwi
Ohio USA
Posts 10
Kiwi Posted: Thu, Dec 31 2020 10:41 PM
This is my first post. I have a question, and yes ive searched the forum for days !
Many of you with Pentas have replaced the foam surrounds on the midranges - probably the vast majority of you, and yes im doing it too !   What are you replacing the cardboard gaskets behind the drivers with ?  Mine are so brittle i really dont want to put them back, 2 broke taking them out, and 1 was crushed from the factory.
Ive made automotive gaskets before and considered doing so in this case, but i cant see getting these as accurate as they would need to be. Very thin 3m foam tape maybe ? Ive never seen one as thin as this would need to be. Love to hear your ideas.
Kiwi.
Kiwi
Ohio USA
Posts 10
Kiwi replied on Tue, Jan 5 2021 12:13 AM
Found some from Audio friends:
https://www.repairyourspeakers.com/en/foam-surrounds/bang-olufsen/bang-olufsen-penta-midrange-8x-foam-gasket-ring/a-2684-10000016
Page 1 of 1 (2 items) | RSS
