Mac mini M1 to Beolab 4 PC - NOISE..!
Not Answered This post has 0 verified answers | 3 Replies | 1 Follower
NavarroOne
Kuala Lumpur
Silver Member
NavarroOne posted on Sat, Dec 26 2020 5:47 AM
I have a pair of BL4PC that I just connected to my brand new Mac mini via a 3.5mm jack. I tried a few cables but there is a lot of noise scratching the instant I plug in the 3.5mm cable!!
I am wondering whether it would be better if I got a Masterlink cable connected to a 3.5mm jack (do they exist?)
Any advice would be appreciated, as the built in speaker on the Mini is atrociously poor.
Beolab 4 PC Type 6651
Beolab 4000 Type 6636 (MK1)
Beolab 8000 Type 6801 (MK1)
Beosound 9000 Type 2561 (MK2)
Aussie Michael
Melbourne, AU
i wonder if a ferrite core might help out that you put on the cable?
NavarroOne
Kuala Lumpur
Silver Member
Thanks mate. My tech specialist guru says lightning have taken the IC back and beyond repair so will protably be looking for a replacement of that and see how that goes.
Millemissen
Flensborg, Denmark
NavarroOne:
I do not understand what your ‘tech specialist guru’ means with ‘lightning have taken the IC back….’.
However, using one of the smaller USB DAC’s that are on the market would improve the sound dramatically (and should not create any noise.
They are relatively cheap - if you get one with volume control it will be a lot easier to adjust the sound.
Page 1 of 1 (4 items) | RSS
