I got two table chargers but I do not understand how to connect to the phone line.
I guess I am missing another component ... but I am not able to find it.
can you please explain how to do it ??
thanks
Hi and welcome to the Forum!
If the table chargers are just simple 'chargers', then they do not allow connection to the phone line - you would need a PSTN base instead. The early pstn bases looked like the pyramid chargers but have a power light on the front. They connect to both mains power and the phone line via a little adaptor like this: https://archivedforum.beoworld.org/media/p/270469.aspx
It's also worth reading this FAQ for background, and information about other pstn options to connect to the phone line: https://www.beoworld.org/faq_view.asp?id=74
Dear sir,
HI again Ferdinando,
I can't see any picutres - there are instructions how to add them here: https://forum.beoworld.org/wikis/memberspages/post-and-upload-pics.aspx
But if your charging base is also a PSTN, then it should have a label underneath with a 'PARK' number. like PARK: 36 - 000077212345.
The Beocom 6000 has several chargers ONLY that are compatible which means they only charge the Beocom 6000 battery. There are also combined base station and chargers and there are base station only units. see chart below
Regards Keith....
