Hello,
Whilst working out the delays in NL it's working as expected, for a while. The M3 stays fine for a ±day or two, i'm able to join a source without problems (V1 / BS35)After this period the M3 does not join using the remote or button, using the app works but the sound is droopy — a pitch lower and sounds 'slow'. Disconnecting the power and trying again the M3 is 'fine' again.
NL delays are ±500ms, connected to 5Ghz network and excellent connection.
Any idea's?
Well, i’m on the latest software and the problem sounds the same, i’ll contact B&O and refer to this topic.
L1NO:After this period the M3 does not join using the remote or button, using the app works but the sound is droopy — a pitch lower and sounds 'slow'. Disconnecting the power and trying again the M3 is 'fine' again.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Library: A6, Beocom 6000 Bedroom: M5 Office: Beocom 2 Travel: Beoplay E8 2.0, Beoplay P2
Hiort: L1NO: After this period the M3 does not join using the remote or button, using the app works but the sound is droopy — a pitch lower and sounds 'slow'. Disconnecting the power and trying again the M3 is 'fine' again. Experience the same thing! A pitch lower sound and voices when joining another source. If I flip to another source and back again, it sound okay again.
Now registred as Ticket 319571
L1NO: Hello, Whilst working out the delays in NL it's working as expected, for a while. The M3 stays fine for a ±day or two, i'm able to join a source without problems (V1 / BS35)After this period the M3 does not join using the remote or button, using the app works but the sound is droopy — a pitch lower and sounds 'slow'. Disconnecting the power and trying again the M3 is 'fine' again. NL delays are ±500ms, connected to 5Ghz network and excellent connection. Any idea's?
Please report to B&O Support
https://support.bang-olufsen.com/hc/en-us/requests/new
For those having the issue with the M3, are you using WiFi Mesh networks or WiFi hostpost with the same name (same SSID)?
mbolo01:For those having the issue with the M3, are you using WiFi Mesh networks or WiFi hostpost with the same name (same SSID)? BS Moment, BS Core, BG 4002, BC 4500, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, P6 (tks Botty), H5, TR1
Hiort:Wi-Fi hotspots (2) with same SSID
mbolo01: Great, thanks. This could be the issue. B&O answered to my M3 case + logs. They pretend my WiFi hotspot is not providing enough bandwidth to my M3 for Deezer listening and that there were some « frequency interferences », suggesting i rename my hotspot ..... Where the analysis’ conclusion makes no sense to me (I’m a network engineer), the recommended solution (ssid rename) rang a bell to me and reminded me about a similar issue the Moment had with mesh networks. As I also have two hotspots sharing the same SSID, and I need that setup, I activated another hotspot, nearby the one used by the M3 previously, name it with a different unique SSID and configured the M3 to use it. My systematic M3 issues (murltiroom drops) have stopped (only one in many hours of listening scenario previously causing drops). I’ll do more test and I’ll feedback B&O. If the ssid rename really solves the issue, this will confirm that since the latest software update, the M3 has trouble with shared ssid , maybe mesh networks too, which was not the case previously as I have this setup since acquired the M3, more than 2y ago.
So you think that would be the cause for the "drooping audio" as well?
And regarding having different SSIDs on the acces points and assign devices to those, do the devices still understand they are on the same network?
Im not very skilled on networks I shall add
Hiort:So you think that would be the cause for the "drooping audio" as well?
mbolo01: It could be. If you have the opportunity to test it by shutting down the less used of your hostspots for the duration of the tests, or you can configure a different SSID on each hostspot, devices connected to them will still be on the same network as before, no issue here. Having the same SSID name is generally useful for hotspots that have the capability to direct the mobile clients to the best hostspot, or, to make your life simpler by configuring only one SSID hoping that your mobile device will select the best one. If you have different SSID names, the mobile device may also choose the best one. I suggest you give a try with the solution that fits the best with your environment. That said, something changed in the M3 WiFi management that is now impacted by configurations like ours.
It could be.
Okay, I will try and report back.
I actually noted the "drooping audio" when my M5 joined my Beosound 1 play just now ,,,, I had do jump to another source and then back again to get it to sound normal again.
Hiort: Okay, I will try and report back. I actually noted the "drooping audio" when my M5 joined my Beosound 1 play just now ,,,, I had do jump to another source and then back again to get it to sound normal again.
Aahrgh....
Got a bit to complicated to do this on my UNIFI AP:s.... Will see if I can manage with one AP and see what happens.
Hiort:Got a bit to complicated to do this on my UNIFI AP:s....
