I have a 3300 turntable. LP records play but not the first 2 inches of the record. Anybody know what the issue is?
Thanks,
Neil
Sounds like it thinks you'r eplaying a 7-inch record.Record size is determined by record weight. Check if the center tap feels spring-loaded.
Martin,
The centre is spring loaded. Turntable knows an LP on the deck as cartridge arm goes to the edge of the LP.
So it actually sets down correctly at the lead-in groove of a 12" LP?
